Hello everyone,
I would like to dump a ROM to a file for use in WINUAE of a SCSI expansion card. What software should I use ?
Thanks
G.
Dumping ROM
Dumping ROM
A2000 - MC68000 - KS3.1 - WB 3.1 - 2MB ChipRAM - Impact A2000-HC+8 Series II - 8 MB FastRAM - SD2SCSI 16GB - Indivision ECS
Re: Dumping ROM
The Expansion_Boot_Roms.zip located in The Zone! on the EnglishAmigaBoard has all the below Roms, if it's there probably just easier to download that.
'3-State Apollo 500_2000.bin'
A2090a.rom
'A4091 v40.13.rom'
'A4091 v40.4.rom'
'A4091 v40.9.rom'
A590_A2091-390388-02-v4.6.bin
A590_A2091-390388-03-v6.0.bin
A590_A2091-390389-02-v4.6.bin
A590_A2091-390389-03-v6.0.bin
A590_A2091-390721-01-v6.1.bin
A590_A2091-390721-02-v6.6.bin
A590_A2091-390721-03-v7.0.bin
A590_A2091-390722-01-v6.1.bin
A590_A2091-390722-02-v6.6.bin
A590_A2091-390722-03-v7.0.bin
A590_A2091_v5.92.even.bin
A590_A2091_v5.92.odd.bin
'AccessX 2000.bin'
Acetec_M27C256B-12F1_ROM_V2.1.bin
'Acetec_M27C256B-12F1_ROM_V2.1 (descrambled).bin'
ALF2_v2.2.bin
Archos_ADD-500_v1.21.rom
'Archos Overdrive HD.bin'
'Ashcom AddHard v2.0.bin'
'Buddha v103.17.rom'
'California Access Malibu v1.0.bin'
'Catweasel v103.17.rom'
'C-Ltd Kronos.bin'
Combitec_2090A_turbo.even.bin
Combitec_2090A_turbo.odd.bin
Combitec_2090B.even.bin
Combitec_2090B.odd.bin
Combitec_2090B_turbo.even.bin
Combitec_2090B_turbo.odd.bin
'Comspec SA-1000 P91-01605 U4-U15.BIN'
'Comspec SA-1000 P91-01606 U5-U16.BIN'
'DKB_RapidFire v1.31.bin'
'ElsatHD 1.0 (09 Oct 1992).even.bin'
'ElsatHD 1.0 (09 Oct 1992).odd.bin'
'Evesham Micro REF1 13Mar93.bin'
'Expansion Systems Dataflyer Plus v1.5.bin'
'Expansion Systems Dataflyer Plus v1.7.bin'
'Expansion Systems Dataflyer Plus v2.0.bin'
'Expansion Systems Dataflyer Plus v2.1.bin'
FastLaneZ3_v8.5.bin
GOLEM_HD3000_5520_1_4.HI.bin
GOLEM_HD3000_5520_1_4.LO.bin
GVP_SCSI_3.7.bin
GVP_SCSI_3.7_even.bin
GVP_SCSI_3.7_odd.bin
GVP_SCSI_v1.0_even.bin
GVP_SCSI_v1.0_odd.bin
GVP_SCSI_v3.15.bin
GVP_SCSI_v4.15.bin
HK_Vector_Falcon8000_v7.1_even.bin
HK_Vector_Falcon8000_v7.1_odd.bin
HK_Vector_Falcon8000_v7.6_even.bin
HK_Vector_Falcon8000_v7.6_odd.bin
'ICD AdIDE_40_44_v33.rom'
'ICD AdIDE_40_44_v34.rom'
'ICD Advantage SCSI v1.6 (icddisk.device v1.0).bin'
'ICD Advantage SCSI v2.2 (icddisk.device v34.0).bin'
'ICD Advantage SCSI v2.x (icddisk.device v33.0).bin'
'ICD Trifecta v4.31.bin'
'IVS Trumpcard 500AT v1.1.bin'
'IVS Trumpcard 500AT v1.2.bin'
'IVS Trumpcard Pro v4.9.rom'
'IVS Trumpcard v1.5.bin'
'IVS Trumpcard v3.1.bin'
'IVS Trumpcard v4.9.bin'
Kommos_SCSI_A500_v1.7_even.bin
Kommos_SCSI_A500_v1.7_odd.bin
Kommos_SCSI_A500_v1.8_even.bin
Kommos_SCSI_A500_v1.8_odd.bin
Kupke_Golem_A500_v3.8.even.bin
Kupke_Golem_A500_v3.8.odd.bin
Kupke_Golem_A500_v3.9.even.bin
Kupke_Golem_A500_v3.9.odd.bin
'Kupke Golem FastSCSI v4.2.even.rom'
'Kupke Golem FastSCSI v4.2.odd.rom'
MacroSystem_2090B_even.bin
MacroSystem_2090B_odd.bin
'Mainhattan Data A-Team v1.8.bin'
Masoboshi_MC-702.bin
'Microbotics HardFrame v1.5.bin'
'Microbotics HardFrame v1.9.bin'
M-Tec_AT_500_Megabody_v133.bin
M-Tec_AT_500_v133.bin
'Multi Evolution 500 SCSI v2.2_even.bin'
'Multi Evolution 500 SCSI v2.2_odd.bin'
'Multi Evolution 500 SCSI v3.0_even.bin'
'Multi Evolution 500 SCSI v3.0_odd.bin'
'Multi Evolution 500 SCSI v3.4_even.bin'
'Multi Evolution 500 SCSI v3.4_odd.bin'
Oktagon_2008_v6.12.bin
'Pacific Peripherals Overdrive v1.5.bin'
'Pacific Peripherals Overdrive v2.0.bin'
'Phoenix Board SCSI J.bin'
'Preferred Technologies Nexus.bin'
'Profex HD3300 v22 17-Apr-1989.bin'
Protar_A500_HD.bin
RocHard_RH800C_v1.0_even.bin
RocHard_RH800C_v1.0_odd.bin
RocHard_RH800C_v2.0_even.bin
RocHard_RH800C_v2.0_odd.bin
'SCRAM16 v1.217.bin'
'SCRAM8 v1.218.bin'
'SupraROM AMAB3.bin'
'SupraROM AMAB4.bin'
'SupraROM AMAB5.bin'
'SupraROM AMAB6.bin'
'Vortex System 2000.bin'
'Xetec FastTrak v1.42.bin'
A2090a.rom
'A4091 v40.13.rom'
'A4091 v40.4.rom'
'A4091 v40.9.rom'
'AccessX 2000.bin'
ALF2_v2.2.bin
'C-Ltd Kronos.bin'
FastLaneZ3_v8.5.bin
GVP_SCSI_3.7.bin
GVP_SCSI_v3.15.bin
GVP_SCSI_v4.15.bin
Protar_A500_HD.bin
'SCRAM8 v1.218.bin'
Re: Dumping ROM
Unfortunately Hardital SuperBigBang is not on this list.LezRed wrote: Sun Nov 29, 2020 9:37 pm The Expansion_Boot_Roms.zip located in The Zone! on the EnglishAmigaBoard has all the below Roms, if it's there probably just easier to download that.
Re: Dumping ROM
I think that the easiest way to dump a ROM is to pull it off the board, insert it into the EPROM programmer, and read it.
- Admin sponsor
Re: Dumping ROM
Agreed. Unless you know specifically which part of address space the rom is mapped its not going to be possible. There is no general tool for pulling roms for all hardware.tzok wrote: Mon Nov 30, 2020 10:53 am I think that the easiest way to dump a ROM is to pull it off the board, insert it into the EPROM programmer, and read it.
If you do know you can use monam2 from Devpac to save off areas of memory. Or write your own tool.
Re: Dumping ROM
That's a shame. The Accelerators section of that zip does have a 'Hardtail TQM.bin' rom image, maybe that'll work given there was only a small number of accelerators from that brand?
Re: Dumping ROM
Unfortunately no, it doesn't work. However I am in contact with Toni Wilen, the developer of WinUAE. I've put the matter to him and he seems interested. I await news ..LezRed wrote: Mon Nov 30, 2020 11:26 amThat's a shame. The Accelerators section of that zip does have a 'Hardtail TQM.bin' rom image, maybe that'll work given there was only a small number of accelerators from that brand?
