68000 relocator for STE/MSTE?
Other boosters or variants.
fenarinarsa
Post by fenarinarsa »
I'm a bit startled to see what's possible with the TF536 on ST.
I'd really like to boost my STE, or possibly even my MSTE.
However before even talking compatibility, the main issue is that on those machines the 68000 is on a PLCC68 socket, not to mention than on STE it's located under the keyboard.
Is there a solution to this, at least like a PLCC68 male/DIP adapter? Or would that mean I'd have to hope for someone to do such a relocator?
DoG
Re: 68000 relocator for STE/MSTE?
Post by DoG »
Nothing exist of such a board or solution to it that I know of for STe and thus it is not tested either.
frank.lukas
Post by frank.lukas »
I have two pcb´s for the mega ste, but you have to desolder the cpu socket and solder the dil adapter in ...
https://forum.atari-home.de/index.php/t ... #msg240119
fenarinarsa
frank.lukas wrote: Wed Nov 18, 2020 9:21 pm I have two pcb´s for the mega ste, but you have to desolder the cpu socket and solder the dil adapter in ...
Oh damn. It's the AT-Speed adapter I suppose?
I thought it could be possible to use a male PLCC68 socket but the only one I find seems to be CMS.
Also if the TF536 has not been tested for STE/MSTE, maybe this won't work at all in the end :/
There's also boards for Amiga 600, but they clip over the 68000 so again desoldering the CPU socket and modifying the board would be required.
Honestly I would try to unsolder the CPU if I was sure of the result because unfortunately I currently don't have enough time on my hands to try all that :(
frank.lukas
The TF should work if the Mega STE run at 8Mhz and cache off. The PAK68/3 works. When the MSTE switch to 16Mhz or the cache on the computer will crash. The Atari Mega STE with TOS 2.06 work at boottime always to 8Mhz and cache off. I not know about EmuTOS?
frank.lukas
Picture ...
fenarinarsa
Interesting... do you sell these?
frank.lukas
Yes, but postage is a problem. From germany I can send only as package without tracking or tracking and no letter. Send me a PM ...
czietz
Post by czietz »
fenarinarsa wrote: Wed Nov 18, 2020 11:59 pm I thought it could be possible to use a male PLCC68 socket but the only one I find seems to be CMS.
I once saw an adapter as you envision for the PAK accelerator: http://atari.wroclaw.pl/pliki/pak1.jpg. However, I have no idea who made those and where they could be bought.
frank.lukas
czietz wrote: Thu Nov 19, 2020 11:14 am
Ask "artik-wroc" at atari-forum.com about stuff from poland ...
Return to “EVERYTHING ELSE”
