Hi!
I'm looking for a program to view and modify the cookie jar, in particular the _IDT cookie. Any recommendations?
Thanks,
Andres.
Utility to edit cooki jar?
- AndresPlazaR
Andres Plaza R.
Bluesky: @aplaza.bsky.social
Twitter: @AndresPlazaR
Andres Plaza R.
- thorsten.otto
Re: Utility to edit cooki jar?
There should be quite some programs that can display the cookie jar (a CPX modules for example). But can't remember one that can change it. Does that make sense at all? Changes will be lost on the next reboot, anyway.
I use this.
- AndresPlazaR
Uh... But the cookie jar, besides being resident in memory, it is represented in a file, right?thorsten.otto wrote: Sun Nov 15, 2020 3:51 am There should be quite some programs that can display the cookie jar (a CPX modules for example). But can't remember one that can change it. Does that make sense at all? Changes will be lost on the next reboot, anyway.
Andres Plaza R.
Andres Plaza R.
- AndresPlazaR
Thanks!!!
Andres Plaza R.
Andres Plaza R.
- thorsten.otto
No. Cookies like _CPU, _VDO, _AKP etc are set by the OS while booting, depending on detected hardware. The _IDT cookie is only set by mint and magic (or by some other tool), but not by TOS or EmuTOS. If you have some CPX that sets this cookie, it is set based on values that are stored in the CPX itself, but only for this specific cookie. There is no file that would represent all the value in the cookie jar.AndresPlazaR wrote: Sun Nov 15, 2020 11:45 am Uh... But the cookie jar, besides being resident in memory, it is represented in a file, right?
- AndresPlazaR
Ah! Thank you very much for the clarification!thorsten.otto wrote: Sun Nov 15, 2020 2:35 pm No. Cookies like _CPU, _VDO, _AKP etc are set by the OS while booting, depending on detected hardware. The _IDT cookie is only set by mint and magic (or by some other tool), but not by TOS or EmuTOS. If you have some CPX that sets this cookie, it is set based on values that are stored in the CPX itself, but only for this specific cookie. There is no file that would represent all the value in the cookie jar.
Andres.
Andres Plaza R.
Andres Plaza R.
