Processors ...
GianDO
Processors ...
Post by GianDO »
Hi,
could anyone explain to me why a MC68010P12 is seen on my A2000 Rev.6 as the original MC68000P8?
Thanks
G.
A2000 - MC68000 - KS3.1 - WB 3.1 - 2MB ChipRAM - Impact A2000-HC+8 Series II - 8 MB FastRAM - SD2SCSI 16GB - Indivision ECS
Re: Processors ...
GianDO wrote: Sat Nov 07, 2020 2:42 pm Hi,
Thanks
G.
Which program are you using?
GianDO
Re: Processors ...
Post by GianDO »
I tryed with SysInfo 4.3, WhichAmiga 1.3.3 (2.5.99) and "cpu" command from shell
Re: Processors ...
GianDO wrote: Sat Nov 07, 2020 3:27 pm I tryed with SysInfo 4.3, WhichAmiga 1.3.3 (2.5.99) and "cpu" command from shell
The only way the Amiga will show you have a 010 is in SysInfo if the VBR gets moved to a non-zero location. Standard CPU utility doesnt show it. Wasnt sure about WhichAmiga.
GianDO
Re: Processors ...
Post by GianDO »
terriblefire wrote: Sat Nov 07, 2020 3:37 pm The only way the Amiga will show you have a 010 is in SysInfo if the VBR gets moved to a non-zero location. Standard CPU utility doesnt show it. Wasnt sure about WhichAmiga.
SysInfo also doesn't show it. So what should I do?
Re: Processors ...
GianDO
Re: Processors ...
Post by GianDO »
terriblefire wrote: Sat Nov 07, 2020 4:39 pm Try VBR move
http://aminet.net/package/util/boot/vbrmov23
I tried to run the VBRMove file from workbench and it appears: "you need a 68010 or higher!"
Re: Processors ...
Seems you have a fake then probably!
GianDO
Re: Processors ...
Post by GianDO »
I'm coming to this conclusion too ...
