TF536 compatibility with A2091 SCSI Card
68030 + SDRAM + IDE
DX93
Post by DX93 »
Hi folks,
I have just gotten a TF536, which I've installed into my A2000 (rev 6.2). It's working well and I'm very pleased with it. Many thanks to its creator for a speedy but affordable accelerator.
There is however one issue that has came up. I have an A2091 SCSI card (with 6.6 ROMs.) It works fine on its own, but it doesn't agree with the TF536. Here is what happens with various different configurations:
A2091 autoboot jumper enabled, SCSI hard drive connected: System does flashing colourful bars, then black - does not proceed - not even the early boot menu from left+right mouse works.
A2091 autoboot enabled, SCSI hard drive disconnected: boots fine.
A2091 autoboot disabled, SCSI hard drive connected, A2091HD driver in SYS:Expansions: boot hangs early in AmigaOS loading. (Mouse remains responsive.)
A2091 autoboot disabled, SCSI hard drive connected, no A2091HD driver in SYS:Expansions: boots fine.
Jumpering the A2091 for either 2MB, 1MB, 512KB, or 0 of its onboard fastram has no effect.
The presence of a hard drive plus the loading of a driver for the card seem to be the necessary and sufficient grounds for the system to hang. The fastram onboard the card works fine.
I understand the A2091 is notorious for disagreeing with accelerators so I am not surprised it is not working right, but if anyone has any ideas on how it might be made to work I would be much obliged. Alternatively if someone knows another SCSI or IDE card (I am hoping to run two CF cards and a CD drive) which works well with the TF536 then that would be another option for me.
Many thanks,
David
alenppc
Re: TF536 compatibility with A2091 SCSI Card
Post by alenppc »
This is the same issue that the CDTV has, and why I added this part to my Amibay FAQ.
The A2091 ROMs are notorious for their DMA issues. I think that if you really need a SCSI controller, you'll have to use a non-DMA one, like the Oktagon.
8 Bit Dreams
Post by 8 Bit Dreams »
..but then again.. Gayle Emulation will not allow You to boot from that device.. At least i am unable to boot fom my LAN-IDE card that has Oktagon bootROM on it when TF536 is installed..
8 Bit Dreams wrote: Tue Nov 03, 2020 10:46 pm ..but then again.. Gayle Emulation will not allow You to boot from that device.. At least i am unable to boot fom my LAN-IDE card that has Oktagon bootROM on it when TF536 is installed..
Thats entirely down to boot priorities of the partitions. no?
EDIT: The presence or otherwise of Gayle is not the issue. Its always down to the specific boot priority of the drive. This is a software thing.
8 Bit Dreams
Hmm.. Not sure, Stephen, may also be an issue with my rev.4.1 A2000..
Just started to build brand new rev.6.2, hopefully will be done @weekend so further tests will be done in near future :idea:
8 Bit Dreams wrote: Tue Nov 03, 2020 11:25 pm Hmm.. Not sure, Stephen, may also be an issue with my rev.4.1 A2000..
Look at the boot drives in the ESM and how they are listed. And what the priorities are.
Johnnybarker
Post by Johnnybarker »
I can confirm that my GVP impact II HC +8 card seems to work fine on my a2000 (Rev 6.2) with the TF536 so that would be an option. They come up quite frequently on ebay. I haven't tried a hard drive on it but I have an external CDROM and zip drive working.
Johnnybarker wrote: Wed Nov 04, 2020 9:11 pm I can confirm that my GVP impact II HC +8 card seems to work fine on my a2000 (Rev 6.2) with the TF536 so that would be an option. They come up quite frequently on ebay. I haven't tried a hard drive on it but I have an external CDROM and zip drive working.
Thanks for that @Johnnybarker
matt020
Post by matt020 »
@Johnnybarker
Before I go out and buy one, could I ask if you have any memory on the GVP card? And if you do, is it enabled?
8 Bit Dreams
Probably he have some memory installed 🤔
GVP card does DMA in Zll memory area and is working fine, if no Memory present in Zorroll - i assume it will crash, ive seen that on TF534..
Return to “TF536”
