Problems with A2000
GianDO
Problems with A2000
Post by GianDO »
Hi,
I have an A2000 with Indivision ECS, a rather strange thing happened to me recently. The A2000 starts up regularly, when the WB appears, the mouse moves regularly, both buttons work, if I click the left button the amount of memory appears at the top if I click the right button the menus with the options appear. However, if I try to click any object on the desktop (not on the desktop empty space), everything on the desktop, icons, drawers, seems to be frozen. If I try to click again with the mouse, nothing happens. The computer works, the click of the floppy is also heard and it does not seem to be blocked. If I reset it or I turn it off and on again the problem is back again.
Since I have recently installed Indivision ECS and I was doing some tests I thought I messed up the operating system, then I rebooted the A2000 from floppy, but nothing has changed, what could have happened?
Thank you
G.
A2000 - MC68000 - KS3.1 - WB 3.1 - 2MB ChipRAM - Impact A2000-HC+8 Series II - 8 MB FastRAM - SD2SCSI 16GB - Indivision ECS
Re: Problems with A2000
I would test without the ECS to see if is a fault of that hardware, and if it is, claim it under warranty or ask for support on their forum, they're really responsive to people.
alenppc
Post by alenppc »
You should specify which ROM version you have on the A2000.
A CIA failure can also cause this type of behaviour.
GianDO
Post by GianDO »
alenppc wrote: Fri Oct 30, 2020 2:14 am You should specify which ROM version you have on the A2000.
ROM 3.1
