Do I have the only 128mb TF536 in existence?
68030 + SDRAM + IDE
Yes, I think I do :lol: 8-)
Re: Do I have the only 128mb TF536 in existence?
I think I'd better say a big thank you to @agranlund for working out how to get 128mb up and running on the ST :D
Post by JezC »
:coolpics: :goodpost:
Possibly the only other thing to add is that I still haven't got the settings right to successfully run any programs in FastRAM, so 64 or 128 is not an issue until I sort that out. :shrug: :foldarms: :( :roll:
Which RAM have you used @PhilC ?
Might be handy for the second H4...
@JezC I think this was the ram I used
INTEGRATED SILICON SOLUTION (ISSI) IS42S16320D-7TLI DRAM, SDR, 512 Mbit, 32M x 16bit, 143 MHz, TSOP-II, 54 Pins
About £12 a chip inc vat.
Have you been using prgflags.tos to set the fastram flags? Oh and you may need to flash the latest firmware with the 64mb fix.
:thumbup: - Nice!
EzdineG
Post by EzdineG »
Not all heroes wear capes, but maybe @agranlund actually does?
PaulJ_2.0
Post by PaulJ_2.0 »
Well I technically have a 128mb TF536, but it only functions as 64MB.
I should maybe swap out the ram, I dont hold much hope in having it working fully now.
@EzdineG I think @agranlund may actually be a secret cape wearer
Post by JezC »
PhilC wrote: Tue Sep 29, 2020 5:36 pm Have you been using prgflags.tos to set the fastram flags? Oh and you may need to flash the latest firmware with the 64mb fix.
@PhilC Thanks for the info on the RAM - I think we use a similar part on one of our designs so will check with our preferred silicon disti to see if they are available from them or not.
I have a prgflags.prg that I've tried to use...but have not seen any real difference in the Gembench figures...assuming I'm using it correctly, of course!
There's a file selector so I just set all the flags to the left of the file list...but don't know how to check for sure whether it actually did anything (it was saying file was read-only even though the info on the desktop said it was writeable)...
:shrug:
Won't get chance today but maybe later this week I'll trawl fro a maual/guide to using it & see what I might be doing wrong...
If I need to re-program the CPLD as well then I guess I'd better work out how to use one of my RasPi boards to do it at some point.
Another potential problem is that I've only got a Gotek connected & working so far...not yet managed to get a CF working on the IDE on the TF536 (I think I need a cable to connect between the TF and the CF adaptor board)...
@JezC I use a cable and cf adaptor from the exxos store. Ill make a simple CF card image soon with stuff on to help you and others get going if that useful?
Return to “TF536”
