H5 A5 BOM (or lack of)
Information and progress towards the H5 board.
I am just dumping this here and are still updating it.. But it is pretty much complete anyway, there really is not much to order other than sockets and a couple of chips.
I have listed store only parts, as these parts you are probably not going to find anywhere else easily.The MOUSER parts are definitely ones which you will need as well.
I have listed some sockets and things which are in my store, but you can buy them from wherever anyway. The bulk of these parts are from a donor machines..But of course the chip can be obtained from my store as well if needed. Are not going to list every socket and such as people can look for them in my store if I sell them anyway, but mostly these should be obtained from a scrap then the machine..
MOUSER PARTS
BATTERY HOLDER (OPTIONAL)	855-S8411-45R
DS1315 RTC (OPTIONAL)	700-DS1315-5
16MHZ OSC (OPTIONAL) 	449-LFSPXO019275BULK
MAX238CWG+		700-MAX238CWGT
3.3V REG		621-AZ1084CD-3.3TRG1
RESET IC		511-STM6315RGW13F
LS02			595-SN74LS02DR
STORE ONLY PARTS
STV8438CVQFP44 DAC	https://www.exxosforum.co.uk/atari/store2/#0104
PLCC 68K CPU   		https://www.exxosforum.co.uk/atari/store2/#0092
MFP 68901 PLCC 		https://www.exxosforum.co.uk/atari/store2/#0148
32.08MHZ OSC		https://www.exxosforum.co.uk/atari/store2/#0006
DUALTOS ROM		https://www.exxosforum.co.uk/atari/store2/#0054
OPTO COUPLER		https://www.exxosforum.co.uk/atari/store2/#0179
GAL22V10
GENERAL PARTS
SQUARE HEADER PINS	https://www.exxosforum.co.uk/atari/store2/#0158
FLOPPY CONNECTOR	https://www.exxosforum.co.uk/atari/store2/#0022
SOCKETS
68K SOCKET	https://www.exxosforum.co.uk/atari/store2/#0038
PLCC44 SOCKET	https://www.exxosforum.co.uk/atari/store2/#0186
DIP40 SOCKET	https://www.exxosforum.co.uk/atari/store2/#0108
PLCC68 3M	517-8468-11B1-RK-TP
SIMM SOCKET 	https://www.exxosforum.co.uk/atari/store2/#0056 / 571-7-5382486-2
PARTS FROM DONER MACHINES
68B50 ACIA X2	https://www.exxosforum.co.uk/atari/store2/#0105
YM2149 SOUND IC	https://www.exxosforum.co.uk/atari/store2/#0103
SHIFTER VIDEO	https://www.exxosforum.co.uk/atari/store2/#0102
ST MMU		https://www.exxosforum.co.uk/atari/store2/#0080
ST GLUE		https://www.exxosforum.co.uk/atari/store2/#0081
ST DMA		https://www.exxosforum.co.uk/atari/store2/#0164 and https://www.exxosforum.co.uk/atari/store2/#0004
EXT FLOPPY DIN	https://www.exxosforum.co.uk/atari/store2/#0100
DMA DB19	https://www.exxosforum.co.uk/atari/store2/#0084
RGB 13 PIN DIN	https://www.exxosforum.co.uk/atari/store2/#0157
wietze
Re: H5 A5 BOM (or lack of)
Post by wietze »
Much appreciated, thanks!
Tomswork
Post by Tomswork »
Ordered the mouser stuff now in the hands of the us post office . I bet I will get the h5 boards first
Tom
Post by JezC »
Thanks @exxos ...though you've put a 48 way DIL socket on that (store item #168) - I thought the images so far showed the PLCC 68901?
Quite happy either way (and I have a spare 48 way DIL socket anyway)...just confused (as usual) :lol: :? :roll:
JezC wrote: Mon Sep 28, 2020 9:58 pm Thanks @exxos ...though you've put a 48 way DIL socket on that (store item #168) - I thought the images so far showed the PLCC 68901?
Oh yep, will remove it.
DoG
Post by DoG »
If anyone wants to socket everything I wrote a list:
Space between pins on DIP = 0,1"/2,54mm
SHIFTER = 40 pin DIP, 2x20 pin, row spacing = 0,6"/15,24mm
DMA = 40 pin DIP, 2x20 pin, row spacing = 0,6"/15,24mm
YM2149 = 40 pin DIP, 2x20 pin, row spacing = 0,6"/15,24mm
WD1772 = 28 pin DIP, 2x14 pin, row spacing = 0,6"/15,24mm
ACIA (6850P) = 24 pin DIP, 2x12 pin, row spacing = 0,6"/15,24mm. 2 of them.
MMU = 68 pin PLCC thru hole, 4x17pin, pin spacing 0,050"/1,27mm
GLUE = 68 pin PLCC thru hole, 4x17pin, pin spacing 0,050"/1,27mm
CPU (MC68000) = 68 pin PLCC thru hole, 4x17pin, pin spacing 0,050"/1,27mm
BLITTER = 68 pin PLCC thru hole, 4x17pin, pin spacing 0,050"/1,27mm
ROM (27C4096) = 44 pin PLCC thru hole, 4x17pin, pin spacing 0,050"/1,27mm
MFP (MC68901) = 52 pin PLCC SMD, 4x13pin, pin spacing 0,050"/1,27mm
GAL22V10 = 24 pin DIP, 2x12, row spacing = 0,3"/7,62mm
DS1315 = 16 pin DIP, 2x8, row spacing = 0,3"/7,62mm
OPTO COUPLER = 6 pin DIP, 2x3, row spacing = 0,3"/7,62mm
IO BUS Sockets = 64 pin DIP, 2x32 pin, row spacing = 0,9"/22,86mm. 6 of them or 12 pieces of 32 pin DIL turned pin socket strips
3V3 IO BUS (IO1-8) = 8 pin DIL turned pin socket strips. 2 of them.
I probably missed something...
Is that a different reset chip compared to last time? the H4 used a MIC6315-29D4UY-TR
PhilC wrote: Tue Oct 20, 2020 5:42 pm Is that a different reset chip compared to last time? the H4 used a MIC6315-29D4UY-TR
Same chip @PhilC different manufacturer.
@Icky thanks, still got some of them :)
Return to “H5 Phoenix Platform Edition”
