H5 A3 FIXES
Information and progress towards the H5 board.
H5 A3 FIXES
Fix #1
@Icky Noticed this, I really don't know how this one passed DRC check :roll: The more I use Eagle the more I am really hating it these days. :cussing: :cussing: :cussing:
error is a short on a via.
FIX
I cut the tiny red / top track next to C9 rather than cutting the track on the bottom...and soldered to C9 pad.
EDIT: Alternative bodge wire underneath the board
DoG
Re: H5 A3 FIXES
Post by DoG »
What? Is the board already being made at the factory?
Re: H5 A3 FIXES
DoG wrote: Sun Sep 27, 2020 9:21 pm What? Is the board already being made at the factory?
Yep.
Re: H5 A3 FIXES
Time to go to KiCAD ;D
Re: H5 A3 FIXES
Fix #2
Same thing I just found again, shorted via on inner layer :roll:
So we need to cut these tracks...But unfortunately IC6 has to be removed as the top track (red) is under it :roll:
OPTION 1 - TO USE WITH FLASHY CLOCK
then a bodge wires has to be run right across the board...
OPTION 2 (neater - but cannot use flashy-clock)
Re: H5 A3 FIXES
Fix #3
Another shorted via :(
I cannot see any more problems anywhere...
Re: H5 A3 FIXES
Is Eagle meant to pick this kind of thing up?
Re: H5 A3 FIXES
Steve wrote: Thu Oct 01, 2020 10:00 pm Is Eagle meant to pick this kind of thing up?
Sometimes it does, then other times not. But the routing tool doesn't seem to see inner layers and shorts stuff out which I don't always notice. Other times when I am routing on a inner layer and there is a top layer track, it will refuse to route past it, like it thinks its all on the same layer. A lot of these bugs have been around since several versions ago.. Then autodesk bolt on new features.. which are buggy as well... @Icky has a collection of rants from me about bugs in Eagle.
IMO Eagle is fine if you want to do 2 layer small boards, but start getting larger and multilayers, it just can't cope. Its got bugs in version 7 which are still in version 9.. and as @Icky knows, I found that many new bugs in V9 I just can't use the thing full stop. Now they bolting fusion360 into it all.. I am just never going to class Eagle as a pro tool anymore, its not even a toy anymore.
I really would move to KiCad if I had the patience to start over.. but better the devil you know as they say... Though I don't know if they listen to bug reports or not anyway.
dragmar
Re: H5 A3 FIXES
Post by dragmar »
@exxos As soon as PCB H5 you have. Did you fix any mistakes before shipping? will everyone have to do it themselves?
Re: H5 A3 FIXES
I really think you have something wrong with your DRC setup. Do you have all the clearances specified for the inner layers?
Return to “H5 Phoenix Platform Edition”
