stfmC103414-001
thecaver99
stfmC103414-001
Post by thecaver99 »
I have one of the above main boards with 512k ram and space for the extra 512k to make 1mb but is there any option to get the 4mb ram upgrade fit as the mmu is soldered to the main board not in a socket so cant plug in the adapter.
are there any sockets about that i can get and remove the mmu and fit and then plug the mmu back in to the adapter board will fit or is there any other way like getting a socket and soldering it to the adapter board and fitting the socket over the mmu like they do with the amiga 600 and 1200s?
really would like to get this to 4mb.
Re: stfmC103414-001
If you look around I think there are RAM upgrades which have bodge wires and the RAM on the shifter board instead. You do look for one of those or just get a easier MB board to work with..
redhawk668
Re: stfmC103414-001
Post by redhawk668 »
I also have a C103414-001 PCB and upgraded it to 4 MB of RAM, you need good soldering skills to perform the mod. This board has 512kb in 4x 4 bit DRAM’s, those need to be removed.
Now, solder in 8x 4 bit 1 mb SOJ DRAM’s. Address line 9 (MAD9) is not connected, pin 5 is address line 9, these pins need to be connected on both memory banks. Solder a 33 ohm resistor to pin 64 of the GLUE chip, connect both wires together and solder to the other end of the resistor. Gives 4 mb of RAM.
Return to “RAM UPGRADES”
