My TF536 build failure
68030 + SDRAM + IDE
amimjf
Post by amimjf »
Hi,
Its taken ages to get around it but finally did my 536,.. but back screen :-) and no boot.
CPLD programs ok, programmed latest version.
5V test points are ok when inserted in 68k socket
Tried in A2000 (rev 6.2) and A500++, same result. Both boards work fine with the 68000 in place.
Looking at some previous threads no1 cause is poor soldering on the tight pitch stuff,.. i've checked it loads of times, but will upload some close ups.
Anything else i should check ?, i dont have a scope at home but could get one from work.
Re: My TF536 build failure
amimjf wrote: Fri Sep 11, 2020 4:53 pm Anything else i should check ?, i dont have a scope at home but could get one from work.
Are you trying to boot Kickstart or DiagROM.. first goal is boot DiagROM.
amimjf
Post by amimjf »
Booting kickstart, i have a DiagROM from the A500++ build, will try that.
Images included.
PaulJ_2.0
Post by PaulJ_2.0 »
If there is nothing at all, I'd check/swap the oscillator. That soldering all looks fairly nice.
PaulJ_2.0 wrote: Fri Sep 11, 2020 5:11 pm If there is nothing at all, I'd check/swap the oscillator. That soldering all looks fairly nice.
Yes i looked at that oscillator and thought... i wonder if thats a crystal and not an oscillator.. i've made that mistake before and it looked like that.
amimjf
Post by amimjf »
Black screen with DiagROM as well.
Clock is a "SIT8008BC"... "100MHz XO (Standard) HCMOS, LVCMOS Oscillator 3.3V Enable/Disable 4-SMD, No Lead" ough no !,.. have i been really dumb ?
PaulJ_2.0
Post by PaulJ_2.0 »
That's a programmable oscillator?
Edit:
Oh it's ok, I just checked the SiT8008BC part number and it took me to a datasheet of a programmable 8-110mhz osc.
amimjf
Post by amimjf »
Datasheet says "Low Power Programmable Oscillator"....
But the exact part i ordered is "SIT8008BC-83-33E-100.000000T", the so 100.00000 should be the frequency,.. i guess a need to scope it.
100mhz is a bit quick for the scopes have i think, is there a place where its divided down i could check ?
amimjf wrote: Fri Sep 11, 2020 5:36 pm Datasheet says "Low Power Programmable Oscillator"....
Yes that part is not correct. Thats a programmable osc. You need a plain 100Mhz osc.
amimjf wrote: Fri Sep 11, 2020 5:36 pm 100mhz is a bit quick for the scopes have i think, is there a place where its divided down i could check ?
The CPU clock at the 030.. grab OpenBoardView and the files from the terriblefire-binaries area... but i think that part is not correct at all I suspect that osc is outputting 2Hz when it boots.
Return to “TF536”
