NVDI5 Crashes Notator.
General Discussion, STOS.
Cosmic Puppet
Post by Cosmic Puppet »
I've just accidentally found another bug whilst testing ClickOff program. I've discovered that whilst in the score editor, pressing either D, (Stem down for selected notes) H, (Enharmonic shift down for selected notes) or W (Syncopation: alternative display) crashes the program.
I installed this for use with EmuTos a long time ago and it made everything slick.
If I run EmuTos alone these crashes disappear. I tested working backwards, deleting ANTIBOMB, SNAPIT, US_GETCL, DESKPIC, and then WDIALOG and NVDI. Then it finally stopped freezing.
I also tested running NVDI without WDIALOG and this still bricked it.
Notator runs slower than normal in EmuTos without NVDI, so this throws my setup into question.
Meh. It's took hours to figure this out. :shock: :D
Thought I'd better let you see this @anodyne
czietz
Re: NVDI5 Crashes Notator.
Post by czietz »
Perhaps try a different, older NVDI version? Many people prefer NVDI 2.5x on the ST.
Cosmic Puppet
czietz wrote: Thu Aug 27, 2020 8:29 pm Perhaps try a different, older NVDI version? Many people prefer NVDI 2.5x on the ST.
Okay, I'll try and find it.
I'm creating another system right now so will be able to test this one a lot.
Cosmic Puppet
It's missing off here but maybe I could test the others.
Annotation 2020-08-27 203726.jpg (42.77 KiB) Viewed 4189 times
Cosmic Puppet
Strike that I can't convert pasti files so I'll look on the atari music network.
frank.lukas
Post by frank.lukas »
When Notator on TOS 1.04 (STE 1.62) is to slow use a Atari TT with Logic or Cubase ...
Cosmic Puppet
NVDI 2.51 doesn't load Notator. :lol:
Blitter ;)
You could try turboST...
Cosmic Puppet
exxos wrote: Thu Aug 27, 2020 11:35 pm Blitter ;)
Do you mean it's acting like I have one?
Cosmic Puppet
Font is odd...
But...
It works!
Fast menu access...
And crashy D, H, and W keys in score editor no more! :mrgreen:
Return to “SOFTWARE”
