SD/CF reader in an A500
68030 + SDRAM + IDE
bnice7
Post by bnice7 »
Hi all! I've been lurking here for a while, finally joined the forum and this is my first post. I built myself a TF536, everything is as stable as can be and what a fun/relaxing build it was too. I took my time with it and with a little hand-holding from Paul J. I got the cpld programmed with no issues. Thanks to TerribleFire for developing this!
I'm curious what solutions people are using to either mount or stash away your IDE/CF or SD card readers? Are you just shoving them inside the case somewhere and isolating to make sure nothing gets shorted, or do you leave it hanging out from the side expansion port? I have a short 44-pin IDE cable, maybe 2 inches long if that. I also have the IDE buffers on-hand if I want to try a longer cable. I'm tempted to try to design something 3D printed, but don't want to re-invent the wheel if there's already a simple solution for this.
8 Bit Dreams
Re: SD/CF reader in an A500
Post by 8 Bit Dreams »
People in Scotland usually dismantle their Amigas and throw all casings away, so swapping cards isn't a problem there, also ide cables are pretty short.. germans usually are storing their hard drives CF & SD cards in neighbours house, so if FBI breaks in while You are hacking Pentagon with Your Amiga A500 - You'll be safe since no physical storage in Your house will be found.. that's why they need long cables and buffered IDE interface lol :lol: :P :P :P
arkadiusz.makarenko
Post by arkadiusz.makarenko »
8 Bit Dreams wrote: Mon Aug 17, 2020 7:07 pm People in Scotland usually dismantle their Amigas and throw all casings away, so swapping cards isn't a problem there,
So not true... I still have case, but I lost all screws. :P
~ Stanislaw Lem
bnice7
Post by bnice7 »
:lol: :lol: That must be a really long IDE cable!
pipper
Post by pipper »
My low tec solution using a SDCard extender
Mark Sealey
Post by Mark Sealey »
lol nie post....love the sd card extender option...i have one in my A600 Furia...As for the A500+ I tried a IDE splitter buffered thing and could not get the second channel to work....!
A500+ Pistorm EMU68... A600 Furia 020/33....A1200 TF1230
Return to “TF536”
