TF534 Not run
dragmar
TF534 Not run
Post by dragmar »
The plate lay for a long time, I decided to solder it
Even soldering went fast, first I soldered without RAM and checked if it starts. He succeeded and began to solder IC RAM and CPLD. The programming went well. But the card does not boot.
I launched DIAGROM. It took off, I checked the RAM and it turned out that the photo will show it better :)
Where is the best place to look for the fault?
!Message from: Moderator
@dragmar, we have placed your attachments in-line so they display correctly in your post. Here's the how-to guide.
arkadiusz.makarenko
Re: TF534 Not run
Post by arkadiusz.makarenko »
It looks like ram issue to me.
Can you do slow manual test fastram region 0x40000000 - 0x4040000 ?
~ Stanislaw Lem
PaulJ_2.0
Re: TF534 Not run
Post by PaulJ_2.0 »
dragmar
Re: TF534 Not run
Post by dragmar »
I started checking IC8 connections. It turned out that the pin had no contact with VCC and A21.
The diagram still shows this error, but I already know it is. THX @ PaulJ_2.0
But I have another problem. The card takes off, but ...
AmigaTestKit shows detected FASTRAM - 4MB.
But when I choose DIRECT MEMORY SCAN the system does not see 4MB
arkadiusz.makarenko
Re: TF534 Not run
I have got the same on my TF534.
~ Stanislaw Lem
Re: TF534 Not run
Can you do a manual memory test? $4000000 - $403fffff if I remember correctly?
PaulJ_2.0
Re: TF534 Not run
Post by PaulJ_2.0 »
I use this and find it works great and finds any actual errors:
https://archive.org/details/Advanced_Am ... -30_Wilcom
dragmar
Re: TF534 Not run
Post by dragmar »
@PhilC I cannot do a manual test, I only have the 8A1 board, the GOTEK and the mouse connected.
But it does the test https://archive.org/details/Advanced_Am ... -30_Wilcom
it's okay so far
I took out the AMIGA board to test the card. Ultimately, the TF534 will land in the ATARI 520ST.
PaulJ_2.0
Re: TF534 Not run
Post by PaulJ_2.0 »
That ram is fine if it does 10 passes with no issues.
arkadiusz.makarenko
Re: TF534 Not run
@dragmar
You could do manual test on Diagrom.
But this card look good for me.
~ Stanislaw Lem
Return to “TF534 (OBSOLETE)”
