The Myth of Three Capacitor Values
Interrsting article. While it can get complicated, in general when using SMT caps, using 3 values increases the track lengths which just causes problems with higher impeedences. I've just used 1 cap for years and when in as doing digital audio circuits, it's actually greatly improved the noise figures.just 5mm track length can break a design. These days keeping track lengths down is more of a factor than the caps, assuming SMT ceramics are used of course.
https://www.signalintegrityjournal.com/ ... tor-values
Edit:
I've also seen 3 caps values causes ossilations. All the inductances and cap values build a very complicate mix of oscillators, found that out the hard way years ago. :roll:
cmorley
Re: The Myth of Three Capacitor Values
Post by cmorley »
Analysing it is very complicated - you're in to modelling rather than beard stroking. I just use one value 100nF everywhere... one per power pin... keeps the BOM down to one type of cap and I've never had a problem with any PCB I've done that way. I'll use other values where datasheets ask (mainly power regulator stability caps) but exclusively 100nF for decoupling.
Since what I do works for me I pretty much ignore the topic..
edit: typo changed uF to nF
I don't really worry about. In terms of decoupling, I think the old school rule was 100nf every 6 cm or something. I just plaster 1uF -10uF close to main chips now. In terms of what we are generally doing, it really does not matter that much anyway.
troed
Post by troed »
Same hour as I read through that I made an order to my local electronics company.
Capacitor MLCC 100nF 50V X7R 2.54mm × 15
I happily noted that they said that if you use MLCC then just go with a "high" value everywhere.
/Troed
Is probably worth noting as well that when you start getting down to 0805 packages, The actual capacity start dropping dramatically when voltages are present across it.. It's why I mostly trying keep to 0805 & 1206 packages and up.
Dave Jones did a video on all this *somewhere* as well not long back.
Return to “ELECTRONICS”
