PHIHONG PSM 2512-2 REV A2 Capacitor replacement help
Repairs & upgrades.
peterhurn
Post by peterhurn »
Hi,
I have a PHIHONG PSM 2512-2 REV A2 in my Atari STE, I would like to recap this, I have looked at the options given the current caps regarding capacitancy, voltage, height, diameter and tried to consider the ripple amount.
I have come up with the following suggested replacements from RS Components, I would have like to have gone for Panasonic but couldn't seem to find the right combination.
What are people thoughts on the followng:
Original - C5 - 1 x 400v 47uF 85c (TEAPO) 22D X 25H mm
Replacement:
https://uk.rs-online.com/web/p/aluminiu ... s/7063272/
RS PRO 47μF Electrolytic Capacitor 400V dc, Through Hole
or
https://uk.rs-online.com/web/p/aluminiu ... s/7441316/
Cornell-Dubilier 47μF Electrolytic Capacitor 400V dc, Through Hole - SLP470M400A1P3
Original C11 - 1 x 50v 1uF 85c (Rubycon) 5D x 10H mm
Replacement:
https://uk.rs-online.com/web/p/aluminiu ... s/7111407/
RS PRO 1μF Electrolytic Capacitor 50V dc, Through Hole
Original - C12 & C13 - 2 x 10v 2200uF 85c (Rubycon) 12D x 20H mm
Replacement:
https://uk.rs-online.com/web/p/aluminiu ... s/7110864/
RS PRO 2200μF Electrolytic Capacitor 10V dc, Through Hole
Original - C14 - 1 x 25v 1000uF 85c (Rubycon) 12D x 20H mm
Replacement:
https://uk.rs-online.com/web/p/aluminiu ... s/7328201/
Panasonic 1000μF Electrolytic Capacitor 25V dc, Through Hole - EEUTP1E102
Original - C15 - 1 x 25v 470uF 85c (Rubycon) 10D x 15H mm
Replacement:
https://uk.rs-online.com/web/p/aluminiu ... s/7111122/
RS PRO 470μF Electrolytic Capacitor 25V dc, Through Hole
Any advice gratefully received.
Peter.
Re: PHIHONG PSM 2512-2 REV A2 Capacitor replacement help
peterhurn wrote: Mon Aug 03, 2020 6:42 pm I have come up with the following suggested replacements from RS Components, I would have like to have gone for Panasonic but couldn't seem to find the right combination.
Replacement:
What about these ? https://uk.rs-online.com/web/p/aluminiu ... s/7083661/
You can use higher voltages. Just have to check physical dimensions. Generally that the dia and pitch, height there is normally plenty of.
Then a quick look, it looks like you can go from 900mA ripple to 2.6amps.
Tomswork
Post by Tomswork »
Does your power supply have a rifa capacitor on it a .01uf x2 275v rectangular shape. Those caps must be replaced they are the worst smelling smoke bombs. Find a Panasonic replacement sometime the parts are listed as 10nf x2 275 polypropylene
Tom
