Is it possible to use a real HDD on the tf536?
68030 + SDRAM + IDE
Cypher0l7
Post by Cypher0l7 »
Setup a real HDD on winuae and it boots fine. But when I put it in my A500+ it won’t boot. If I hold both mouse buttons I have cc0 card disk.
Re: Is it possible to use a real HDD on the tf536?
Cypher0l7 wrote: Mon Aug 03, 2020 4:34 pm Setup a real HDD on winuae and it boots fine. But when I put it in my A500+ it won’t boot. If I hold both mouse buttons I have cc0 card disk.
It should work but you will need very short cables or the buffers added.
neilo40
Post by neilo40 »
I had mine working with a real disk for a bit. The cable is ~2 inches long
alenppc
Post by alenppc »
It also depends on the disk. Some work, some don't. I tried this back with the 530 but haven't tried it again since.
Cypher0l7
Post by Cypher0l7 »
Sorted.
Needed to put the links in for df0 selection. Also plugged a drive in.
Return to “TF536”
