Wire Gotek to CDTV internally and externally
bartekmalysz
Post by bartekmalysz »
as per topic. How to wire it internally if such option exists (memory card connector??) And how to wire it externally? Can I just connect external amiga floppy drive connector with gotek 1-1 or I need a driver board? Any schematic would he useful. Thanks
arkadiusz.makarenko
Re: Wire Gotek to CDTV internally and externally
Post by arkadiusz.makarenko »
I have both external drive options. External cable without any chips, this gotek is seen as last floppy in chain. So if you have df0 and df1 then gotek will be seen as df3.
And I have modified external floppy where drive were floppy was replaced with gotek drive.
Both solutions work, first one is quite ugly. If I find it i will post picture of it.
~ Stanislaw Lem
utri007
Post by utri007 »
Buy old external disk drive, wich has a floppy drive broken. Usually Gotek is drop in replacement for it. I wouldn't put it internal. Those who has done it has usually soldered cable under the external floppy connector.
