CosmosEx V3
Various other hardware solutions.
marss1
CosmosEx V3
Post by marss1 »
Hi,
Can anyone provide a link to the image SD file for Falcon as mine is corrupted and the one from the official ftp seems to be also corrupted?
Thanks.
Re: CosmosEx V3
Specifically what image do you mean?
An image for the Raspberry Pi software?
An image for the SD card that the machine will boot from?
Have you tried http://jookie.sk? There are RPi images there, just make sure you get the latest, otherwise I'd suggest you get in touch with with the guys at Atari.sk.
ube
Re: CosmosEx V3
Post by ube »
master of the bare pcb
marss1
Re: CosmosEx V3
Post by marss1 »
Yes, an image for the SD card that the machine will boot from.
marss1
Re: CosmosEx V3
Post by marss1 »
Hi,
Under MINT+Teradesk+MyAES+CosmosEX3, the letter N is assigned to the USB stick but 'Path not found' when I click on N ;(
Any suggestions?
Thanks
mikro
Re: CosmosEx V3
Post by mikro »
Forum cross-posting is not exactly a good way to get more help. You have been told on the other forum that FreeMiNT + CE setup is simply not supported at this time. And now you're asking it again.....
Return to “HARDWARE ESSENTIALS”
