NEW STORE ITEMS
NEW STORE ITEMS
Thought I would start a thread of new items which are added to my store every now and then.
Currently the new item is the TC511001AP DRAM Is mostly used in some mega ST's
https://www.exxosforum.co.uk/atari/store2/#0185
As always, all these chips get tested before going into my stock. I think there is nothing worse In doing a RAM upgrade for it not to work and then you wonder if your soldering sucks, or the ICs are faulty.. At least if you buy from my store, you can be rest assured it is your soldering which sucks :lol:
Re: NEW STORE ITEMS
PLCC44 SOCKETS. These are 3M branded not cheaper ones. I'm generally heading towards only stocking sockets which I know are reliable,
https://www.exxosforum.co.uk/atari/store2/#0186
I was in 2 minds if to sell these in packs of two or not as it would better value for people. Though it is a double-edged sword that most people will probably only want one socket anyway. Not really expecting these to be huge sellers, but as mentioned elsewhere, with me wanting to sell these sockets separately to kits, then people may buy them from my store just buy them elsewhere if they prefer.
Re: NEW STORE ITEMS
FLOPPY PCB CONNECTOR 34 WAY
https://www.exxosforum.co.uk/atari/store2/#0022
Primarily used on the remake boards, but also can be used on originals
Re: NEW STORE ITEMS
TOS206 ST decoder board.
https://www.exxosforum.co.uk/atari/store2/#0172
A compact TOS104 / TOS206 decoder board which can plug-in (or solder) into any existing 68000 socket. It also has the ability to have a socket on top for a CPU or accelerator.
NOTE : You will need a DUALTOS board & ROM to use this on a original ST machine. H4 boards only require the DUALTOS ROM.
Re: NEW STORE ITEMS
PGA 128 PIN SOCKET
https://www.exxosforum.co.uk/atari/store2/#0181
NEW 3M PGA socket for 030 CPU. Sourced from reputable manufactures and not cheap sockets from China!
I only have a limited stock of these and will be unable to buy any more once my stocks are exhausted.
Re: NEW STORE ITEMS
Jumper links
https://www.exxosforum.co.uk/atari/store2/#0188
https://www.exxosforum.co.uk/atari/store2/#0189
030 RC CPU
https://www.exxosforum.co.uk/atari/store2/#0187
Re: NEW STORE ITEMS
One thing which has been in the pipeline for very long time is replacement floppy drive belts...
These are now in stock.
https://www.exxosforum.co.uk/atari/store2/#0193
Re: NEW STORE ITEMS
FUNKY PLCC68 used sockets.
https://www.exxosforum.co.uk/atari/store2/#0195
2x22 2mm pin header IDE.
https://www.exxosforum.co.uk/atari/store2/#0196
Re: NEW STORE ITEMS
A couple more new items in stock now.
50mhz 5v oscillators . these are getting harder to find so bulk brought a lot of them.
https://www.exxosforum.co.uk/atari/store2/#0201
74F257 as used on the STE https://www.exxosforum.co.uk/atari/store2/#0202
Re: NEW STORE ITEMS
Finally got a few cartridge pulls for my store. These have been in the ultrasonic cleaner for about half an hour to clean up the contacts. I have tried to keep the pins straight as possible but will likely need a bit of tweaking and cleaning up of residual solder etc
https://www.exxosforum.co.uk/atari/store2/#0203
Locked
