Ram choices for TF536
68030 + SDRAM + IDE
I thought I would start a topic where we can share details of working and non-working ram chips.
Firstly, for a 64mb version of the card, I have had great success with the recommended Micron chips but have just been testing the ISSI IS42S16160G-7TLI the first board has been running well for a couple of hours so far.
For the 128mb version (no firmware support just yet but it will come hopefully) I plan to test the ISSI IS42S16320D-7TLI with the next TF536 I build.
I'll edit this first post with known tested chips and the results.
Tested chips for 64mb version.
Micron MT48LC16M16A2P-6A:G Original specified ram, works well.
ISSI IS42S16160G-7TLI Works on test board, test duration 6 hours.
Samsung K4S561632J-UC75 Working fine.
micron 48lc16m16a2-75 Tested by @Justme14 and @PaulJ_2.0
Tested chips for 128mb version.
Alliance Memory AS4C32M16SA-7TCN Tested working to 64mb
ISSI IS42S16320D-7TLI tested to 64mb
alenppc
Re: Ram choices for TF536
Post by alenppc »
Samsung K4S561632J-UC75 works great also.
alenppc wrote: Thu Jul 16, 2020 9:05 pm Samsung K4S561632J-UC75 works great also.
Thanks, adding it to the list
Justme14
Post by Justme14 »
Hi ,
For my tf536 build I used the slower micron 48lc16m16a2-75 and have no issues
PaulJ_2.0
Post by PaulJ_2.0 »
Justme14 wrote: Thu Jul 16, 2020 10:11 pm Hi ,
I too have had no problems with these @ -75
thanks, will add to the list
8 Bit Dreams
Post by 8 Bit Dreams »
FAIR WARNING:
Seems that Samsung RAM isn't working with latest RC2 Firmware! Card hangs in reboot loop after FW is updated. So can't recommend this RAM to be used atm...
Don't know about ISSI, hope guy's used this type of ram will report here soon..
8 Bit Dreams wrote: Sat Aug 15, 2020 9:43 am FAIR WARNING:
I've updated the first post to mention the problems with RC2, thanks.
alenppc
Post by alenppc »
No issues here...
8 Bit Dreams
Tested on A2000 with several TF536 cards - no joy, hence this warning :geek:
Return to “TF536”
