So I started off with just hooking up an AVR to the ASCI bus, and bit-banging a few things, but I pretty soon realised there's no way it can react fast enough to work, so I gave up on that attempt. That was last year. At that time I quickly learned why you need an FPGA.
My second prototype, which is where I'm up to now, adds a low-cost FPGA (MAX-V 5M40Z which is crazy cheap at only 90 US cents! But hard to solder as it has a pad on the bottom) into the mix. I just put a large plated through-hole under the chip and insert the tip of the soldering iron into that hole from underneath to melt the solder. That's probably not the ideal way to do it but it has worked so far
Here's a pic of it:
I used some through-hole parts because I assumed I was going to be adding bodge wires, and I was right - I've had to add two - although unfortunately I still had to connect them to the FPGA (in the middle of the board) which is super tiny. Subsequent to this pic I had to add a second one.
I added a breakout in the middle of the cable for my cheap ebay logic analyser - and it's a good thing I did because I have relied on that thing extremely heavily.
The good news is, I don't think I need to add any more wires, because the physical communication part seems to be working OK now. I have only implemented TEST UNIT READY and INQUIRY at the moment, but the ST is communicating with it, both in command-mode transfers and in data-mode. I think you need to implement about 6 or so commands for it to be deemed a real working device.
The next step will be to add dummy data transfers and then after that, actual communication with the SD card.
