Hi all,
On the TF536, which pin is pin 1 on the IDE header?
Cheers.
Matt.
TF536 - which pin is pin 1 on IDE header?
- arkadiusz.makarenko
- Moderator Team
Re: TF536 - which pin is pin 1 on IDE header?
You should see a dot in one corner which indicates Pin 1?matt020 wrote: Wed Jul 15, 2020 1:38 pm Hi all,
Cheers.
Matt.
~ Stanislaw Lem
~ Stanislaw Lem
snifferman
the one on the side of cristal oscillator. There is a small white dot on PCB for indication
Yes, it's close to the oscillator. But even if you happen to plug it backwards, unlike the A1200, the card won't blow up (it won't boot though).
