Buffered IDE splitter on tf536...?
68030 + SDRAM + IDE
Mark Sealey
Post by Mark Sealey »
Hi awesome ppl
Has anybody used a IDE splitter on there TF536 idefix97....?
Thanks
Mark :D
A500+ Pistorm EMU68... A600 Furia 020/33....A1200 TF1230
alenppc
Re: Buffered IDE splitter on tf536...?
Post by alenppc »
I haven't but if you have one go ahead and try it.
Mark Sealey
I might do.... :D
Ive been :D trying to get my AlphaData AT bus working with the TF534....(I can partion the HDD etc but it never works correctly)
Mark Sealey
Just a update....As much as i try I fear there is no way of having a second IDE channel on the TF536 rev 2b....I've tried a buffered IDE splitter...as soon ad you plug anything into it...there's no boot.....no luck with a AlphaData AT-Bus..with rom or Octapussy.
Lynxman
Post by Lynxman »
Two drives work for me on one long cable on a buffered TF536. I tried with my CF adapter as slave and it then booted to the SDcard on the sdcard adapter on the same cable.
Mark Sealey
ah....my TF536 is not buffered :shock:
alenppc
Post by alenppc »
Mark Sealey wrote: Wed Jan 20, 2021 7:12 pm ah....my TF536 is not buffered :shock:
Mark would you like me to add buffers to yours?
matt020
Post by matt020 »
Mark Sealey wrote: Sun Dec 13, 2020 9:06 pm Just a update....As much as i try I fear there is no way of having a second IDE channel on the TF536 rev 2b....I've tried a buffered IDE splitter...as soon ad you plug anything into it...there's no boot.....no luck with a AlphaData AT-Bus..with rom or Octapussy.
Just on this, for anyone adding a second device on the IDE chain...
Check the IDE/CF adapter, if the underside has solder pads then it is likely to be configured for a master and slave on that card, and anything else you add to the bus will conflict with the slave part of the IDE/CF adapter. If it has solder pads, even though nothing is soldered to it, the device is still configured with an active slave. Tip: the Chinese IDE/CF adapters generally DO have empty solder pads underneath and ARE configured for master/slave.
I got caught out on this, pulled my hair out for some time. I then found a CF adapter that was purely master only, and BOOM she worked
Mark Sealey
alenppc wrote: Wed Jan 20, 2021 11:14 pm
Not really mate...thanks for the offer though....its not the end of the world if i dont have a second device.
Mark Sealey
matt020 wrote: Thu Jan 21, 2021 12:22 am
I`m using a IDEtoSD adapter and there`s no Master/Slave Selection jumper.....
Return to “TF536”
