New MMULibs is out 04.07.2020
68030 + SDRAM + IDE
8 Bit Dreams
Post by 8 Bit Dreams »
Hi guys,
Just wanna let You know that Thomas released a new MMULibs
http://aminet.net/util/libs/MMULib.lha
What was changed/added:
Release 46.19
- The MMU-Configuration file allows now one additional command,
namely "MMU off". This turns off usage of the MMU. The
purpose of this command is to allow safe usage of the MMULib
based processor libraries (68040.library and 68060.library)
on EC processors where the mmulib internal MMU detection logic
reports incorrectly the presence of a MMU. Unfortunately, the
MMU test cannot be made 100% reliably as Motorola labeled
processors with defective MMU as "EC" models, though they were
produced from the same mask set.
- P5Init was updated to also configure the MMU for the Permedia2
and Voodoo3 chips which were present on some P5 based graphics
cards with proprietary PCI bridge. This may help to operate
these cards on MMULib based installations.
With best regards,
- 8 Bit Dreams
Return to “TF536”
