RGB SCART - ARGHHH
- GadgetUK164
RGB SCART - ARGHHH
Hi,
I recently purchased an RGB SCART cable from Cool Novelties. I am finding the TV is outputting Composite (displays CVBS instead of RGB up top). Looking at how its wired, it has Composite going through an 82ohm resistor to the sync/comp pin on the SCART hood. RGB lines are attenuated via 150ohm resistors. The blanking pin has the VSYNC signal going directly to it.
Does everything sound correct there - it seems to match more or less what all the guides out there show, but I just don't get RGB. I am assuming the VSYNC signal is OK (since its used in various places internally), and RGB must be OK or Composite wouldn't look correct as it does. This leaves me wondering what on earth is going on. Pretty sure on my other ST I had it ouputting RGB with another cable a few years ago on the same TV, and I know the TV is fine. Any ideas or suggestions before I start scoping things to see if I can understand what's going on?
Re: RGB SCART - ARGHHH
composite is normally used for sync for RGB to stop the "jail bars". Though the TV shouldn't switch to composite, it should switch to RGB.
- GadgetUK164
Yeah, that's the problem, it's not switching to RGB - always just shows Composite. I've seen that behaviour before in other cables, and normally you can feed 5v through a resistor to lower it to say 2 to 3v, and normally that switches anything into RGB, provided red, green, blue and sync (composite) are there. I wonder if maybe red,green, or blue aren't getting through - having said that, pretty sure I've seen the TV still switch into RGB if a colour is missing. That just leaves the sync being wierd or something.exxos wrote: Sat Jun 27, 2020 6:34 pm composite is normally used for sync for RGB to stop the "jail bars". Though the TV shouldn't switch to composite, it should switch to RGB.
EDIT: It's an ST I've repaired btw. I did notice that VSYNC goes straight from GLUE out to the video socket - doesn't it need coupling?
RGB switch might need 12V on the TV, or it doesn't support auto switching. 5V isn't enough. needs to be at least 9V IIRC.
- GadgetUK164
Tried that too! Still doesn't switch into RGB! It has to be something related to the Composite signal I think.exxos wrote: Sat Jun 27, 2020 7:30 pm RGB switch might need 12V on the TV, or it doesn't support auto switching. 5V isn't enough. needs to be at least 9V IIRC.
EDIT: Tried my other ST - that's the same! So at least I know it's not something specific to the one ST! I will scope things tomorrow and seee if I can work out what it is. I think its just revenge of the weird ST video output and my TV just not liking it. Sure I had this working in RGB with another cable years ago though =/
How many SCART inputs does the TV have? If multiple then many TVs only accept RGB on one of them, the other(s) will be composite/SVideo only.
You could tie V&H sync together like in the STF schematics and use that for "composite" ... its only there for the sync anyway. Or you can just not use composite at all and just tie V&H sync to the scart, but image quality will likely suffer a bit that way.GadgetUK164 wrote: Sat Jun 27, 2020 8:11 pm Tried that too! Still doesn't switch into RGB! It has to be something related to the Composite signal I think.
But can you not manually set the input on the TV regardless of it switching to composite ?
- Admin sponsor
Just incase you guys have missed this (which i doubt)
Spec says....
16 RGB switching (2V = RGB; (0V = Composite Video)
http://fr.meric.free.fr/Articles/articl ... nector.pdf
Pin 16
Blanking signal up
RGB-selection voltage up
0–0.4 V → composite
1–3 V → RGB
http://martin.hinner.info/vga/scart.html
Audio/RGB switch / 16:9
High (9.5-12V) AVmode
Low (0-2V) TVmode
I've always had to drive at 12v.
Low (0-2V) TVmode
Some scart sockets are wired differently. There used to be several scart cables back in the day depending on TV manufacture.Many TV sets have 2 SCART sockets. One is usually loke table 1 and the other like table 2, and pin 20 switchable from composite to S-Video luminance.
The first can switch from a composite input to RGB input. The second can switch from a composite input to an S-Video input, pin 20 being either composite in or luminance in. Usually the second socket outputs a selectable composite signal on pin 19.
For my Sinclair QL I use 3V, two AAA batteries in a holder to switch. That's been reliable on all the TVs I've used.
@exxos those voltages/specifications are for Pin 8, not Pin 16, and not quite correct.
0V-2V Off
5V-8V 16:9 aspect ratio
9.5V-12V 4:3 aspect ratio
0V-2V Off
