Hello,
Thanks for the suggestions. And Yes, I did try several controllers.
To make sure that they are OK, I've also had them in a Mega STE. And there they did HD just fine.
And I have tested 4 controllers in total, so it's not those.
So next I put a 16Mhz oscillator to the input of the floppy PCB.
And I tried to format a HD floppy and read it. Format did work fine now. Just not for 1,44Mb, but it did finish. (Tos 2.06 Formatting)
Also, I could read a 1,44Mb disk and start a program from that disk.
And the 720Kb just kept working of course.
So next I reconnected the Buffer output, using a thinner wire.
I can't believe it makes a difference, but now it works as well.
As promised, the pictures.
I currently have 5 Mega ST boards "in the works" and use them for tests. (Every time with an "Exxos transformer supply")
The object is to test a couple of boards and speeders.
Magnum 10MB, Compro-Tos 2.06, PP-Flash-Tos and IDE, Exxos-Toscard, Pak68-2, HBS240, AD-Speed by ICD, 68020 speeder, HBS640, Hypercache-Turbo.
All of these work in some combination. The Magnum card is sometimes a "spoilsport"
The only card I didn't get to work is the SST card. But it does give a blank screen in Hi-Res and sometimes reboots.
And I still have to test the Pak68/3.
BR/
Guus
- IMG_0499.JPG (1.97 MiB) Viewed 9075 times
- IMG_0501.JPG (2.27 MiB) Viewed 9075 times
- IMG_0502.JPG (2.23 MiB) Viewed 9075 times
- IMG_0503.JPG (2.52 MiB) Viewed 9075 times
!Message from: Moderator
@guus.assmann, we have placed your attachments in-line so they display correctly in your post. Here's the
how-to guide.
