[Atari TT] Width column row isn't constant
sappas
Post by sappas »
Hello,
I suspect c300868 TT video chip, my mother board is a rev A or B,
As you can see the width of column row.
Any advice ?
Thanks
Sappas
Atari TT column row width issue
Re: [Atari TT] Width column row isn't constant
Looks more like the monitor isn't able to sync with the TT's output and so you're getting moire patterns on the screen.
sappas
Post by sappas »
I've to take a better photography, and with compression artefact but on my falcon, it's perfect !
The Falcon outputs standard VGA timed signals, the TT doesn’t. They are outside the acceptable range for standard VGa.
sappas
Post by sappas »
stephen_usher wrote: Mon May 25, 2020 10:58 pm The Falcon outputs standard VGA timed signals, the TT doesn’t. They are outside the acceptable range for standard VGa.
Hello, You're rigth, finally between my twenty 5/4 monitor i've found a LG L1915S witch is less bad.
Thanks a lot, for indicate me the right parh.
This issue is close
My MSTE shows similar problems when used with a VGA display and in Med-Res. It's quite possible to tweak the settings in the monitors control panel to improve the picture sufficiently to make it acceptable.
I was able to fine tune the horizontal size and use auto contrast to get a great picture. Happens a lot on ST's at Med-Res using VGA displays.
