smd fuses.
philbo34
smd fuses.
Post by philbo34 »
im struggling to find some ccp2e50te and ccp2e30te fuses
i usually use farnell but no joy .
found a place in spain but as i only want 1 of each seems expensive with postage .
cheers
Re: smd fuses.
What package and rating etc are they ?
philbo34
Re: smd fuses.
Post by philbo34 »
package size is 1210
2a and 1.2a
Re: smd fuses.
Those 2 number are list on evilbay...
Farnell sell various 2amps ones...
https://uk.farnell.com/search?st=1210%202a%20fuse
1.2A I cannot find, so you will have to use 1A or 1.5A.
Even so, CCP2E50TE lists as 5Amp on evilbay https://www.ebay.co.uk/i/172205248693?chn=ps
CCP2E30TE lists as 3A on evilbay https://www.ebay.co.uk/itm/10Pcs-KOA-CC ... 2679640825
Farnell list 3A and 5A, but 5amp no longer sold
https://uk.farnell.com/w/c/circuit-prot ... 210%20fuse
Mouser sell 5A versions.
https://www.mouser.co.uk/Circuit-Protec ... exZ1yzvlko
Re: smd fuses.
I use resetable fuses on my USB boards. RS have a good supply of them.
philbo34
Re: smd fuses.
Post by philbo34 »
Cheers for advice gents.
I have found another doc that shows they are the rating you mentioned.
I will double check the correct rating and go from there ...knew I should of left PS2 in cupboard
Return to “ELECTRONICS”
