http://nedopc.com/lvd/Projects/
This A600 memory board has two variants. The 2008 version can do three modes. 8mb,4mb, 4mb+1.5mb slow fast ram.
The 2007 version can either do 4mb or 8mb depending on the firmware installed.
I figured it should be possible do a firmware fix to impliment the 4mb+1.5mb version without the need of config pins
as that was the reason for the bigger cpld in the 2008 edition.
So far ive managed to recompile the 4mb source with quartus 8.1 with a lot of help from lvd - this works fine
I then modified code to allow for the non autoconfig memory from $C00000 - $C7FFFF It was easier to just allow
an extra 1mb of memory as it was a simple binary adjustment.
All I get at the moment is a bright pink screen, but this was tried on a A500+
original code
// chip selector decoder
always @*
begin
casex( high_addr )
8'b001xxxxx: // $200000-$3fffff
begin
{which_ras[0],which_ras[1],which_ras[2],which_ras[3]} <= 4'b1000; // /RAS0
mem_selected <= 1'b1;
end
8'b010xxxxx: // $400000-$5fffff
begin
{which_ras[0],which_ras[1],which_ras[2],which_ras[3]} <= 4'b0100; // /RAS1
end
default:
begin
{which_ras[0],which_ras[1],which_ras[2],which_ras[3]} <= 4'b0000; // nothing
mem_selected <= 1'b0;
end
endcase
end
Modified code
always @*
begin
casex( high_addr )
begin
end
begin
end
//modified section
8'b11000xxx: // c00000-c7ffff - slow memory mapping
begin
{which_ras[0],which_ras[1],which_ras[2],which_ras[3]} <= 4'b0001; // /RAS3
end
default:
begin
end
endcase
end
If anyone can help I would be extremely greatful
600 Memory board modification
Re: 600 Memory board modification
I will post the quartis project files once I've cleaned up them up slightly, as some of the original project files are no longer available.
Just checking you've seen the versions from mkl?:
http://www.mkl211015.altervista.org/ram ... dcode.html
I have, but the memory chips are extremely difficult to get. I have found one seller, but they want $7 a chip
