Anyone debug why this crashes ?
All it does is run x& = Maddalt&(4194304,2097152) but when the program finishes , it will say program terminated (as expected) but then it bombs... but why ?
FRAM.zip
(11.48 KiB) Downloaded 253 times
As far as I can tell, it crashes on RTS, so I assume its a stack issue..
mfro
Re: Anyone debug why this crashes ?
Post by mfro »
Maddalt() adds/hooks memory previously not known into internal GEMDOS memory management.
If it crashes, I would assume the added memory is either not where you told GEMDOS or it was already included in the internal management before (error checking is very simplistic, as I recall).
Other than that, it's impossible to tell without knowledge what you exactly do on what exact hardware and how it was initialised before.
And remember: Beethoven wrote his first symphony in C.
The alt-ram is where its supposed to be, I verified the RAM locations in STOS. So its there. So there shouldn't be any problem in allocating it. But it mostly seems to be when the installer quits, I get 4 bombs.
https://www.exxosforum.co.uk/forum/viewt ... &start=270
mfro
Post by mfro »
exxos wrote: Sat Apr 04, 2020 11:22 am The alt-ram is where its supposed to be, I verified the RAM locations in STOS. So its there. So there shouldn't be any problem in allocating it. But it mostly seems to be when the installer quits, I get 4 bombs.
I would probably start with a specialised RAM test routine to make sure it works reliably?
mfro wrote: Sat Apr 04, 2020 12:40 pm I would probably start with a specialised RAM test routine to make sure it works reliably?
Works fine when I access it from STOS.
Still don't get why it doesn't work..
All I do is x& = Maddalt&(4194304,2097152)
If I run this inside GB6, it installs and lets me run tests, but then bombs when I try and exit the program.. When I just run the line on its own...
I don't know how to install the FRB cookie, so maybe thats the problem ?
Tried to program this in ASM, it compiles but when I run it, I get 4 BOMBs :(
	move.l	$200000,d1
	move.l	$400000,d0
	move.l	d1,-(sp)		; Size
	move.l	d0,-(sp)		; Addr
	move.w	#20,-(sp)		; Maddalt
	trap	#1				; GEMDOS
	lea		10(sp),sp
mikro
Post by mikro »
Well if that was really it, no wonder - you need to correctly terminate it - see https://freemint.github.io/tos.hyp/en/g ... tml#Pterm0. And while you are at it, adding Mshrink() at the beginning wont hurt either ;) - https://freemint.github.io/tos.hyp/en/g ... ml#Mshrink, for usage see: http://tho-otto.de/hypview/hypview.cgi? ... 8&index=35
thorsten.otto
Post by thorsten.otto »
That should probably read:
	move.l	#$200000,d1     ; <--
	move.l	#$400000,d0     ; <--
	trap	#1				; GEMDOS
	lea		10(sp),sp
	clr.w -(sp)
	trap #1
Thanks..
So this doesn't bomb, but doesn't seem to install alt-ram either :(
	move.l	$200000,-(sp)		; Size
	move.l	$400000,-(sp)		; Addr
	trap	#1				; GEMDOS
	lea		10(sp),sp
	move.w    #0,-(sp)     ; Offset 0
	trap      #1           ; GEMDOS
	addq.l    #2,sp        ; Correct stack
