Monster alt-ram and TOS104 problem with cookies ?
General Discussion, STOS.
I have been trying to get monster working on a H4.. Though I am stuck with TOS104 and the installer says it cannot install the FRB cookie.. it works with TOS206...
So is there a program to actually install the cookiejar on TOS104 ? or is it TOS206+ only ?
Atarian Computing
Re: Monster alt-ram and TOS104 problem with cookies ?
Post by Atarian Computing »
exxos wrote: Thu Apr 02, 2020 4:49 pm I have been trying to get monster working on a H4.. Though I am stuck with TOS104 and the installer says it cannot install the FRB cookie.. it works with TOS206...
Happy fresh new MonSTer owner checking in. That is working as intended. Only TOS2.06, EMUTOS, MAGIC work with the alt-ram.
ah, never thought alt-ram wouldn't work with TOS104 :roll:
It does seem possible to install the cookies on TOS104.. but probably no point looking...
http://info-coach.fr/atari/documents/ge ... 2-1990.pdf
frank.lukas
Post by frank.lukas »
CookieJar program ...
INSJAR.zip
(5.2 KiB) Downloaded 214 times
I think there is no Altram/Fastram support with TOS 1.04.
frank.lukas wrote: Thu Apr 02, 2020 5:00 pm I think there is no Altram/Fastram support with TOS 1.04.
Thanks.
Does anyone know of a program which will install the alt-ram FRB cookie in TOS206 ? Or know how to code it (though I would have to use basic for this)
thorsten.otto
Post by thorsten.otto »
Installing the cookie isn't that difficult (provided there is already a cookie jar, and there is room for another entry; if that is not the case things are a bit more complicated, but since you will need at least TOS 2.x for Alt-RAM anyway, that is unlikely)
The difficulty here is due to the fact that the buffer the _FRB points to must remain valid after the program terminates. That usually means you have to terminate your program by a Ptermres() call rather than just exiting. Although surely doable, i think basic is not the best choice for such a program.
But IIRC, wasn't there some program for the Monster that already does exactly this?
thorsten.otto wrote: Thu Apr 02, 2020 9:01 pm But IIRC, wasn't there some program for the Monster that already does exactly this?
Yeah, but they made it only work with monster :roll:
I did a installer in GB6, but I get odd thing happen afterwards. If I use monster, those things don't happen, its why I thought it might be a cookie issue.
thorsten.otto
exxos wrote: Thu Apr 02, 2020 9:05 pm Yeah, but they made it only work with monster :roll:
Maybe i missed something, but whats the point to install a _FRB cookie if the monster can't be detected? ;)
thorsten.otto wrote: Thu Apr 02, 2020 9:25 pm Maybe i missed something, but whats the point to install a _FRB cookie if the monster can't be detected? ;)
Because I have my own alt-ram board and can't use monster driver with it.
Return to “SOFTWARE”
