So brought a water cooler and after day 1 had to take it to bits. Girlfriend being a girl didn't understand the "reason" for doing it...
- 13653482_10207254570458228_2523325307286577262_o.jpg (394.96 KiB) Viewed 1934 times
So added a pot to fiddle the temp sensor on the tank. It was cutting off at 15C, so wanted to tweak the sensor a bit to fool it into thinking the water was hotter than it was so it would cool it down some more.
- 13923402_10207254570418227_721306251508455423_o.jpg (390.92 KiB) Viewed 1934 times
While I was at it, needed a bigger fan... Faster fan.. louder fan... Now the thing purrrrrs
- 13914109_10207254570538230_1531049367722063332_o.jpg (417.8 KiB) Viewed 1934 times
Trying to work out where all the bits go...
- 13934687_10207254570978241_6224656346443561955_n.jpg (122.73 KiB) Viewed 1934 times
New fan connections.. Decided bodge tape wasn't viable as these wires run near the heatsink.
- 13886892_10207254571138245_186742139296448005_n.jpg (133.25 KiB) Viewed 1934 times
Circuit Board and fan assembly going back into place.
- 13925489_10207254571218247_5337210556202373594_o.jpg (339.57 KiB) Viewed 1934 times
Pipes connected back up almost..
- 13920245_10207254571778261_7508089881178174059_o.jpg (292.3 KiB) Viewed 1934 times
Trying to work out how to get the lid back on...
- 13963009_10207254571818262_2096708742510313926_o.jpg (290.93 KiB) Viewed 1934 times
- 13995631_10207254571858263_2467424539777749983_o.jpg (300.31 KiB) Viewed 1934 times
Still trying to work out how to get the lid back on...
- 13669453_10207254572258273_6814878437801440097_o.jpg (250.31 KiB) Viewed 1934 times
Force the bloody thing down...
- 13937871_10207254572338275_5203099936453146460_o.jpg (304.54 KiB) Viewed 1934 times
Nope...
- 13975380_10207254572378276_3255273748910121912_o.jpg (281.16 KiB) Viewed 1934 times
Sometime later....
- 13902789_10207254572938290_1822679398696475149_n.jpg (81.65 KiB) Viewed 1934 times
Up the rear view shot.
- 13873234_10207254572978291_4174441262942169221_n.jpg (102.31 KiB) Viewed 1934 times
Pot added.. Nice long hard straight shaft..
- 13987396_10207254573018292_2428528595359440204_o.jpg (236.59 KiB) Viewed 1934 times
..with a big knob...
- 13679960_10207254573578306_834617099801302365_o.jpg (314.43 KiB) Viewed 1934 times
Nothing like a big knob..
- 13906708_10207254573658308_6877015148823058435_n.jpg (100.92 KiB) Viewed 1934 times
First test run.. Blue light still comes on, so progress..
- 13909131_10207254574218322_6171931474386476148_o.jpg (315.08 KiB) Viewed 1934 times
Cut out some of the vents to increase airflow some more..
- 13876382_10207254574298324_7241877278416228316_n.jpg (110.65 KiB) Viewed 1934 times
13Deg C.. progress...
- 13886920_10207254574338325_4976337045303097536_n.jpg (67.91 KiB) Viewed 1934 times
The customary "left over screw" which doesn't seem to go anywhere...
- 13903387_10207254575298349_4909121425159295199_n.jpg (106.39 KiB) Viewed 1934 times
All back together.. time for a fiddle with me big knob..
- 13882702_10207254575738360_1730401269174536832_n.jpg (115.09 KiB) Viewed 1934 times
Some time later.. we have now 7degC ! Not bad at all. So now girlfriend hopefully knows why a good fiddle is good
- 13912316_10207254575898364_7266516341686577518_n.jpg (89.89 KiB) Viewed 1933 times
If left on long enough the cooler now spits out icecubes
