TOS checksums ?
TOS checksums ?
Example TOS206.HI has a checksum of 07 C8... But does anyone know how this is created ? I tried various checksums in winhex but can't seem to match it. Really I want a way of doing this in basic :)
OK this looks a bit more complicated that I thought... Can someone "translate" ? :lol:
		text
 * uint16_t check_rom_crc(void *start, long count, short offset)
 * For 512k ROMs in 4x128k chips (TOS 3.x), call with
 *      check_rom_crc(0xe00000, 0x1fffe, 4)
 *      check_rom_crc(0xe00001, 0x1fffe, 4)
 *      check_rom_crc(0xe00002, 0x1fffe, 4)
 *      check_rom_crc(0xe00003, 0x1fffe, 4)
 * For 512k ROMs in a single chip (TOS 4.x), call with
 *      check_rom_crc(0xe00000, 0x7fffe, 1)
 * For 256k ROMs in 2x128k chips (TOS 2.x), call with
 *      check_rom_crc(0xe00000, 0x3fffe, 2)
 *      check_rom_crc(0xe00001, 0x3fffe, 2)
 * Older TOS (192k images) do not have a checksum.
/* 306de: 00e01724 */
/* 206de: 00e015b4 */
check_rom_crc:
        movea.l   4(a7),a0
        move.l    8(a7),d2
        movea.w   12(a7),a1
        clr.w     d0
        clr.w     d1
        clr.w     d3
        lea.l     rom_crc_table,a2
ckcrc1:
        move.w    d0,d1
        lsl.w     #8,d0
        lsr.w     #8,d1
        move.b    (a0),d3
        adda.l    a1,a0
        eor.b     d3,d1
        add.w     d1,d1
        move.w    0(a2,d1.w),d4
        eor.w     d4,d0
        subq.l    #1,d2
        bne.s     ckcrc1
        rts
	data
rom_crc_table:
	dc.w $0000,$1021,$2042,$3063,$4084,$50a5,$60c6,$70e7
        dc.w $8108,$9129,$a14a,$b16b,$c18c,$d1ad,$e1ce,$f1ef
        dc.w $1231,$0210,$3273,$2252,$52b5,$4294,$72f7,$62d6
        dc.w $9339,$8318,$b37b,$a35a,$d3bd,$c39c,$f3ff,$e3de
        dc.w $2462,$3443,$0420,$1401,$64e6,$74c7,$44a4,$5485
        dc.w $a56a,$b54b,$8528,$9509,$e5ee,$f5cf,$c5ac,$d58d
        dc.w $3653,$2672,$1611,$0630,$76d7,$66f6,$5695,$46b4
        dc.w $b75b,$a77a,$9719,$8738,$f7df,$e7fe,$d79d,$c7bc
        dc.w $48c4,$58e5,$6886,$78a7,$0840,$1861,$2802,$3823
        dc.w $c9cc,$d9ed,$e98e,$f9af,$8948,$9969,$a90a,$b92b
        dc.w $5af5,$4ad4,$7ab7,$6a96,$1a71,$0a50,$3a33,$2a12
        dc.w $dbfd,$cbdc,$fbbf,$eb9e,$9b79,$8b58,$bb3b,$ab1a
        dc.w $6ca6,$7c87,$4ce4,$5cc5,$2c22,$3c03,$0c60,$1c41
        dc.w $edae,$fd8f,$cdec,$ddcd,$ad2a,$bd0b,$8d68,$9d49
        dc.w $7e97,$6eb6,$5ed5,$4ef4,$3e13,$2e32,$1e51,$0e70
        dc.w $ff9f,$efbe,$dfdd,$cffc,$bf1b,$af3a,$9f59,$8f78
        dc.w $9188,$81a9,$b1ca,$a1eb,$d10c,$c12d,$f14e,$e16f
        dc.w $1080,$00a1,$30c2,$20e3,$5004,$4025,$7046,$6067
        dc.w $83b9,$9398,$a3fb,$b3da,$c33d,$d31c,$e37f,$f35e
        dc.w $02b1,$1290,$22f3,$32d2,$4235,$5214,$6277,$7256
        dc.w $b5ea,$a5cb,$95a8,$8589,$f56e,$e54f,$d52c,$c50d
        dc.w $34e2,$24c3,$14a0,$0481,$7466,$6447,$5424,$4405
        dc.w $a7db,$b7fa,$8799,$97b8,$e75f,$f77e,$c71d,$d73c
        dc.w $26d3,$36f2,$0691,$16b0,$6657,$7676,$4615,$5634
        dc.w $d94c,$c96d,$f90e,$e92f,$99c8,$89e9,$b98a,$a9ab
        dc.w $5844,$4865,$7806,$6827,$18c0,$08e1,$3882,$28a3
        dc.w $cb7d,$db5c,$eb3f,$fb1e,$8bf9,$9bd8,$abbb,$bb9a
        dc.w $4a75,$5a54,$6a37,$7a16,$0af1,$1ad0,$2ab3,$3a92
        dc.w $fd2e,$ed0f,$dd6c,$cd4d,$bdaa,$ad8b,$9de8,$8dc9
        dc.w $7c26,$6c07,$5c64,$4c45,$3ca2,$2c83,$1ce0,$0cc1
        dc.w $ef1f,$ff3e,$cf5d,$df7c,$af9b,$bfba,$8fd9,$9ff8
        dc.w $6e17,$7e36,$4e55,$5e74,$2e93,$3eb2,$0ed1,$1ef0
	text
Re: TOS checksums ?
It looks like its taking a bank size of $1fffe and adding every 4th byte up.. I will have to start a routine and see if things add up anywhere..
 * check the ROM crc
#if STBOOK | (TOSVERSION >= 0x400)
banksize equ $3fffe
numbanks equ 1
#else
#if TOSVERSION < 0x300
banksize equ $1fffe
numbanks equ 2
#else
banksize equ $1fffe
numbanks equ 4
#endif
#endif
        move.l    #banksize,d7
        move.w    #numbanks-1,d6
        movea.l   #_os_entry,a5
crccheck:
        move.w    #numbanks,-(a7)    /* checksum over every nth byte */
        move.l    d7,-(a7)           /* number of bytes */
        move.l    a5,-(a7)           /* buffer address */
        bsr       check_rom_crc
        adda.w    #10,a7
        movea.l   a5,a0
        adda.l    d7,a0
#else
        adda.l    #banksize*numbanks,a0
#endif
        move.b    (a0),d1            /* high byte of CRC */
        lsl.w     #8,d1
        move.b    numbanks(a0),d1    /* low byte of CRC */
        cmp.w     d1,d0
        bne.s     crcfail
        addq.l    #1,a5
        dbf       d6,crccheck
#if TP_50 /* PAK */
        bra       crcok
#else
        bra.s     crcok
#endif
crcmsg: dc.b 'WARNING: BAD ROM CRC IN CHIP ',0
crcmsg2 dc.b '.',13,10,0
crcfail:
        move.l    a5,d5
        pea.l     crcmsg
        move.w    #9,-(a7)
        trap      #1
        move.b    #$45,d0            /* 'E' - even */
        btst      #0,d5
        beq.s     chipE
        move.b    #$4F,d0            /* 'O' - odd */
chipE:
        move.w    d0,2(a7)
        move.w    #2,(a7)
        trap      #1
#if TOSVERSION >= 0x300
        btst      #1,d5
        beq.s     chipE2
chipE2:
        move.w    d0,2(a7)
        move.w    #2,(a7)
        trap      #1
#endif
        move.l    #crcmsg2,2(a7)
        move.w    #9,(a7)
        trap      #1
        addq.w    #6,a7
        addq.l    #1,a5
Going by the data sizes (8x32) it would work out each 4 numbers would be a checksum of 1023 bytes...
Re: TOS checksums ?
Do you even need the rom crc any more? Surely it's easier to nop the jump to the routine? Or something similar?
First crack I did on the Amiga was just a simple nop, I did start easy though, with battle chess.
Re: TOS checksums ?
I guess it could be skipped.. Though I think I rather have it there... It helps with debugging booters etc.
thorsten.otto
Re: TOS checksums ?
Post by thorsten.otto »
These are C-routines to check & update the CRCs. They are copied from another project, so are somewhat incomplete: the file loading routines are missing, and you have to set some variable like the length of the tos file, and the version which can be extracted from the header.
#include <stdio.h>
#include <stdint.h>
#include <stdlib.h>
#include <string.h>
static unsigned char *tosmem;
static size_t tossize;
static size_t tosstart;
static unsigned short tos_version;
static int is_emutos;
#define ONE_KB (1024u)
static unsigned short const crc_tab[256] = {
	0x0000, 0x1021, 0x2042, 0x3063, 0x4084, 0x50a5, 0x60c6, 0x70e7, 0x8108, 0x9129, 0xa14a, 0xb16b, 0xc18c, 0xd1ad, 0xe1ce, 0xf1ef,
	0x1231, 0x0210, 0x3273, 0x2252, 0x52b5, 0x4294, 0x72f7, 0x62d6, 0x9339, 0x8318, 0xb37b, 0xa35a, 0xd3bd, 0xc39c, 0xf3ff, 0xe3de,
	0x2462, 0x3443, 0x0420, 0x1401, 0x64e6, 0x74c7, 0x44a4, 0x5485, 0xa56a, 0xb54b, 0x8528, 0x9509, 0xe5ee, 0xf5cf, 0xc5ac, 0xd58d,
	0x3653, 0x2672, 0x1611, 0x0630, 0x76d7, 0x66f6, 0x5695, 0x46b4, 0xb75b, 0xa77a, 0x9719, 0x8738, 0xf7df, 0xe7fe, 0xd79d, 0xc7bc,
	0x48c4, 0x58e5, 0x6886, 0x78a7, 0x0840, 0x1861, 0x2802, 0x3823, 0xc9cc, 0xd9ed, 0xe98e, 0xf9af, 0x8948, 0x9969, 0xa90a, 0xb92b,
	0x5af5, 0x4ad4, 0x7ab7, 0x6a96, 0x1a71, 0x0a50, 0x3a33, 0x2a12, 0xdbfd, 0xcbdc, 0xfbbf, 0xeb9e, 0x9b79, 0x8b58, 0xbb3b, 0xab1a,
	0x6ca6, 0x7c87, 0x4ce4, 0x5cc5, 0x2c22, 0x3c03, 0x0c60, 0x1c41, 0xedae, 0xfd8f, 0xcdec, 0xddcd, 0xad2a, 0xbd0b, 0x8d68, 0x9d49,
	0x7e97, 0x6eb6, 0x5ed5, 0x4ef4, 0x3e13, 0x2e32, 0x1e51, 0x0e70, 0xff9f, 0xefbe, 0xdfdd, 0xcffc, 0xbf1b, 0xaf3a, 0x9f59, 0x8f78,
	0x9188, 0x81a9, 0xb1ca, 0xa1eb, 0xd10c, 0xc12d, 0xf14e, 0xe16f, 0x1080, 0x00a1, 0x30c2, 0x20e3, 0x5004, 0x4025, 0x7046, 0x6067,
	0x83b9, 0x9398, 0xa3fb, 0xb3da, 0xc33d, 0xd31c, 0xe37f, 0xf35e, 0x02b1, 0x1290, 0x22f3, 0x32d2, 0x4235, 0x5214, 0x6277, 0x7256,
	0xb5ea, 0xa5cb, 0x95a8, 0x8589, 0xf56e, 0xe54f, 0xd52c, 0xc50d, 0x34e2, 0x24c3, 0x14a0, 0x0481, 0x7466, 0x6447, 0x5424, 0x4405,
	0xa7db, 0xb7fa, 0x8799, 0x97b8, 0xe75f, 0xf77e, 0xc71d, 0xd73c, 0x26d3, 0x36f2, 0x0691, 0x16b0, 0x6657, 0x7676, 0x4615, 0x5634,
	0xd94c, 0xc96d, 0xf90e, 0xe92f, 0x99c8, 0x89e9, 0xb98a, 0xa9ab, 0x5844, 0x4865, 0x7806, 0x6827, 0x18c0, 0x08e1, 0x3882, 0x28a3,
	0xcb7d, 0xdb5c, 0xeb3f, 0xfb1e, 0x8bf9, 0x9bd8, 0xabbb, 0xbb9a, 0x4a75, 0x5a54, 0x6a37, 0x7a16, 0x0af1, 0x1ad0, 0x2ab3, 0x3a92,
	0xfd2e, 0xed0f, 0xdd6c, 0xcd4d, 0xbdaa, 0xad8b, 0x9de8, 0x8dc9, 0x7c26, 0x6c07, 0x5c64, 0x4c45, 0x3ca2, 0x2c83, 0x1ce0, 0x0cc1,
	0xef1f, 0xff3e, 0xcf5d, 0xdf7c, 0xaf9b, 0xbfba, 0x8fd9, 0x9ff8, 0x6e17, 0x7e36, 0x4e55, 0x5e74, 0x2e93, 0x3eb2, 0x0ed1, 0x1ef0
static uint16_t calc_crc(uint32_t pos, uint32_t size, uint32_t inc)
	uint16_t sum;
	uint16_t run;
	uint8_t *p;
	p = tosmem + pos;
	sum = run = 0;
	do {
		run = sum;
		sum <<= 8;
		run >>= 8;
		run ^= *p;
		sum ^= crc_tab[run];
		p += inc;
	} while (--size != 0);
	return sum;
int check_rom_crcs(void)
	uint32_t size;
	uint32_t banksize;
	uint32_t crcpos;
	uint16_t crc, sum;
	int i, banks;
	size = tossize;
	 * check the current crc.
	 * not all tos versions perform a CRC check,
	 * and the file that we loaded might have been patched already,
	 * so we don't update the crc if it wasn't right before
	if ((tos_version >= 0x400 && tos_version < 0x500) && size > 256 * ONE_KB)
		 * Falcon TOS 4.x: a single 512KB ROM
		banks = 1;
		banksize = ((size + 1) & ~1) - 2;
	} else if ((tos_version == 0x206 || tos_version == 0x207 || tos_version == 0x208) &&
		size > 256 * ONE_KB &&
		!is_emutos)
		 * ST-Book TOS 2.x: a single 256KB ROM
		 * The second half of the image contains a cartridge ROM
		banks = 1;
		banksize = (((size >> 1) + 1) & ~1) - 2;
	} else if (size > 256 * ONE_KB)
		 * TT TOS 3.x: 4 128KB ROMs
		banks = 4;
		banksize = (((size + 3) / 4) & ~1) - 2;
	} else if (size > 192 * ONE_KB)
		 * STE TOS 2.x: 2 128KB ROMs
		banks = 2;
		 * size should be only -4 (for the 4 checksum bytes at the end),
		 * but i've seen patched TOSes that are 1 byte too short,
		 * hence the +1
		banksize = (((size + 1) / 2) & ~1) - 2;
	} else
		 * TOS 1.x: 6 32KB ROMs, without CRC
		banks = -1;
		banksize = 0;
	if (banks > 0)
		for (i = 0; i < banks; i++)
			crc = calc_crc(tosstart + i, banksize, banks);
			crcpos = tosstart + banksize * banks + i;
			sum = (tosmem[crcpos] << 8) | tosmem[crcpos + banks];
			if (crc != sum)
				banks = 0;
				fprintf(stderr, "TOS: WARNING: BAD ROM CRC IN CHIP %d\n", i);
	if (banks > 0)
		fprintf(stderr, "TOS: CRC for %uKB ok\n", size >> 10);
	return banks > 0;
void update_rom_crcs(void)
	uint32_t size;
	uint32_t banksize;
	uint32_t crcpos;
	uint16_t crc, sum;
	int i, banks;
	size = tossize;
		banks = 1;
		!is_emutos)
		banks = 1;
		banks = 4;
		banks = 2;
		 * hence the +1
	} else
		banks = -1;
		banksize = 0;
	if (banks > 0)
			tosmem[crcpos] = crc >> 8;
			tosmem[crcpos + banks] = crc;
			if (sum != crc)
				fprintf(stderr, "ROM checksum %d updated from %04x to %04x\n", i, sum, crc);
Re: TOS checksums ?
Based upon that code, here's a CRC fixing program.
Usage: fixcrc tos.img
If the CRC is not correct it writes a modified file out with the same name but with the suffix ".new" added.
I've not tried compiling it under Linux or anything else other than macOS using gcc but it's all just using standard C library stuff.
fixcrc.zip
(3.4 KiB) Downloaded 104 times
!Message from: Moderator
@stephen_usher, we have placed your attachments in-line so they display correctly in your post. Here's the how-to guide.
sporniket
Re: TOS checksums ?
Post by sporniket »
exxos wrote: Thu Jan 02, 2020 10:19 pm It looks like its taking a bank size of $1fffe and adding every 4th byte up.. I will have to start a routine and see if things add up anywhere..
The offset is because bytes are split among eprom chips, so the crc is done chip by chip ?
AndresPlazaR
Re: TOS checksums ?
Post by AndresPlazaR »
Hello!
Sorry to revive this old discussion but... does any of you have been successful calculating the CRC?
I used the code mentioned here; I also interpreted the (supposedly) TOS code from https://github.com/sarnau/AtariSTRomLis ... %2C206.asm and also looked at the code of https://atari.8bitchip.info/ROMSPLIT.ZIP (that, by the way, has a slightly different CRC table than the one in fixcrc); I also used the CRC table directly from the ROM (instead of the table in the code, just in case), and I haven't been able to reproduce a known "good" CRC (I'm testing with TOS for STBook).
One particular thing that it is different between the fixcrc code with the other two, is that the other two have an instruction:
add.w   d1,d1
(add d1 to d1 and put the value in d1, 16 bits operation. d1 is the value shifted 8 bits to the right, the one called "run" in fixcrc)
but this is not reflected in the "calc_crc" function in "checksum.c".
Doing that operation causes d1/run to be out of boundaries in some cases, so... kind of it shouldn't be there? But it is in the ROM...
Bottom line: I'm confused. :lol:
So, any light in this would be appreciated!
Take care,
Andres.
Andres Plaza R.
Bluesky: @aplaza.bsky.social
Twitter: @AndresPlazaR
