Slow STFM blitter oddness
I started a new topic based on this problem...
https://www.exxosforum.co.uk/forum/view ... 450#p31052
Where in short, the blitter in a STFM is actually running slower than in a STE.
It does seem odd that some tests like blitting,VDI graphics and GEM window still run at 100%, But other tests are as slow as 80%.
I can only think for some reason the bus grant stuff is slower than on a STE, but it does not really make sense considering the blitting test is not slowed down. But saying that, that test in particular is mostly copying blocks of RAM about, mostly the VDI tests are more accessing ROM. So there would have to be something strange where when the blitter is accessing ROM, that something like the bus grant acknowledge cycles run a cycle or two slower than they should be doing.
:shrug:
So I wonder if anyone out there with a logic analyser that can be hooked up to a STFM with blitter (or H4 remake board with blitter) and can monitor...
CLK,BR,BG,BGACK,AS,DTACK, ROM CE.
Maybe we can see something odd in the cycles between the blitting test and first test in GB6.
pixelpusher
Re: Slow STFM blitter oddness
Post by pixelpusher »
Have you looked into the software side?
- What is used in GB6' vdi scroll test (vs. an ordinary blitting operation)?
- text operations have to access the font data in the ROM. Does this slowdown also happen, if you load a TOS version into RAM?
- Is this slowdown confirmed by NVDI's GEM_TEST too?
czietz
Post by czietz »
Didn't read the other thread, but did you confirm that the reference file really shows (close to) 100% on everything on a stock STE with (unpatched) TOS 2.06?
czietz wrote: Tue Dec 31, 2019 5:53 pm Didn't read the other thread, but did you confirm that the reference file really shows (close to) 100% on everything on a stock STE with (unpatched) TOS 2.06?
Yep, tried it on 2 STEs. Icky suggested trying a internal and eternal blitter STE, just to be sure, and everything was 100% exactly.
Would help if someone could confirm these odd results just the same though.
czietz
Post by czietz »
I have two STfs with Blitter; but I can only run test on them next weekend.
pixelpusher wrote: Tue Dec 31, 2019 5:28 pm - What is used in GB6' vdi scroll test (vs. an ordinary blitting operation)?
This is all controlled by TOS, nothing changes in GB6.
pixelpusher wrote: Tue Dec 31, 2019 5:28 pm - text operations have to access the font data in the ROM. Does this slowdown also happen, if you load a TOS version into RAM?
A good thought, unfortunately I have never been able to get TOS in RAM working :(
pixelpusher wrote: Tue Dec 31, 2019 5:28 pm - Is this slowdown confirmed by NVDI's GEM_TEST too?
There would be tricky as I am not really familiar with those results or exactly what it does or does not use the blitter for.
PaulJ
Post by PaulJ »
Lot closer on the H4.
PaulJ wrote: Tue Dec 31, 2019 6:21 pm Lot closer on the H4._zzz.jpg
Interesting.. Those 99%'s may just be down to clock variations..
So we really need someone to try a STFM with blitter really now..
pixelpusher
There is a raster copy function in the VDI (which directly utilizes the blitter, if enabled) and an "expansion" (of monochrome) raster function in the VDI, but no "vdi scrolling function" - hence my question what vdi calls GB6 uses in the blitting and vdi scroll test.
GEM_TEST (2) allows you to you to enable/disable the blitter for each test (although the blitter only influences output tests of course).
pixelpusher wrote: Tue Dec 31, 2019 6:46 pm There is a raster copy function in the VDI (which directly utilizes the blitter, if enabled) and an "expansion" (of monochrome) raster function in the VDI, but no "vdi scrolling function" - hence my question what vdi calls GB6 uses in the blitting and vdi scroll test.
But if if this was a TOS issue, surely it would be the same issue on the STE as well using TOS206 ?
TEST 1
DEF TEST1&
'shared tree&
STATIC t&,x,y,w,h,i,obadr&
x=0
junk=rsrc_gaddr(0,form1,tree&)
obadr& = tree&+ (form1*24)
form_center tree&,x,y,w,h
'attempt to sync timerC
SHARED testcode&,sys_tstart,sys_sleep,sys_wake,sys_tstop,sys_acia_off,sys_acia_on,sys_acia_reset
t&=1234567890 ' store some dummy number to write to in ASM code later
call loc testcode&,sys_sleep' ok
call loc testcode&,sys_acia_off ' crash 16mhz tests
call loc testcode&,sys_tstart  ' stores start time internally
FOR i=0 TO 19
	form_dial FMD_START,0,0,0,0,x,y,w,h
	form_dial FMD_GROW,x+w\2,y+h\2,0,0,x,y,w,h
    'form_center tree&,x,y,w,h
    junk=objc_draw(tree&,form1,10,x,y,w,h)
	form_dial FMD_SHRINK,x+w\2,y+h\2,0,0,x,y,w,h
	form_dial FMD_FINISH,0,0,0,0,x-20,y,w+20,h
	x=x+2
POKEW obadr&+16,x
NEXT i
call loc testcode&,sys_tstop,varptr(t&) ' get test time from ASM code
TEST1&= t&*5  ' returns test time from function
call loc testcode&,sys_wake
call loc testcode&,sys_acia_on
END DEF
BLITTING test.
DEF TEST11&
'setup XY locations
SHARED mfdb&,scr&,menuy,XY(),menuy,WYS
STATIC x,y,a,mywind_id,w1,h1,t&
mywind_id=freewind
w1=639:h1=199-menuy
WINDOW OPEN mywind_id,"Blitting",0,menuy,w1,h1,&hfef
'draw test box
vsf_interior 2
vsf_color 1
'this -2's cheat so we copy the white border around the box
'this is a poormans "clear background" as the copy happens
v_bar 10+2,WYS+2,210-2,WYS+50-2
xy(0)=10:xy(1)=WYS:xy(2)=210:xy(3)=WYS+50 'S
call loc testcode&,sys_sleep : call loc testcode&,sys_acia_off
for A=0 to 2 'number of left right loops
FOR X=0 to 400 step 2
xy(4)=10+x:xy(5)=120-y:xy(6)=210+x:xy(7)=xy(5)+xy(3)
vro_cpyfm 3,xy(),mfdb&,scr&
y=(x+1)/6
NEXT X
FOR X=400 to 0 step -2
y=(x+1)/6
NEXT X
NEXT A
TEST11&= t&*5  ' returns test time from function
call loc testcode&,sys_wake : call loc testcode&,sys_acia_on
vsf_color 1
WINDOW CLOSE mywind_id
END DEF
