Floppy drive broken.
- Cosmic Puppet
I think the head is out of alignment or something. I didn't notice Fast Copy was set to HD and now my drive can't see the floppy disks or format them. I got a message on fast copy that said something like "head at 0 Abort".
- Cosmic Puppet
Re: Floppy drive broken.
Okay, it reads other disks but 2 that worked are now not.Cosmic Puppet wrote: Tue Oct 29, 2019 7:50 pm I think the head is out of alignment or something. I didn't notice Fast Copy was set to HD and now my drive can't see the floppy disks or format them. I got a message on fast copy that said something like "head at 0 Abort".
Do the easy bit first, carefully clean the floppy drive heads with IPA and make sure the drive eject mechanism is operating correctly and positioning the disk correctly every time
- Cosmic Puppet
Other disks are working. The configuration is all wrong in the fast copy pro. It now says "can't save FAT abort. I've basically not broken it but rendered two floppy disks useless unless I can set the correct disk configuration. How many sectors etc.PhilC wrote: Tue Oct 29, 2019 8:04 pm Do the easy bit first, carefully clean the floppy drive heads with IPA and make sure the drive eject mechanism is operating correctly and positioning the disk correctly every time
Can't you just click on the FAT DD button as shown https://www.exxosforum.co.uk/forum/viewt ... ?f=25&t=52
- Cosmic Puppet
If I do that it sets the configuration at 11 sectors and 82 tracks. I've manually put it to 09 sectors and 79 tracks and then saved the configuration and now have a disk that the Atari can see again.exxos wrote: Tue Oct 29, 2019 8:15 pm Can't you just click on the FAT DD button as shown https://www.exxosforum.co.uk/forum/viewt ... ?f=25&t=52
- Cosmic Puppet
second disk just failed with "Cannot write the FATs!"Cosmic Puppet wrote: Tue Oct 29, 2019 8:21 pmIf I do that it sets the configuration at 11 sectors and 82 tracks. I've manually put it to 09 sectors and 79 tracks and then saved the configuration and now have a disk that the Atari can see again.exxos wrote: Tue Oct 29, 2019 8:15 pm Can't you just click on the FAT DD button as shown https://www.exxosforum.co.uk/forum/viewt ... ?f=25&t=52
- Cosmic Puppet
Got it. Just had to make sure get sectors used was switched on.Cosmic Puppet wrote: Tue Oct 29, 2019 8:23 pmsecond disk just failed with "Cannot write the FATs!"Cosmic Puppet wrote: Tue Oct 29, 2019 8:21 pm
10 sectors 82 tracks is all some 720K drives can manage.
- Cosmic Puppet
The Fat DD setting caused a horrid noise from my drive and I had to abort when it said something about the head. I thought Read Disk Config would take care of it. Mine only formatted at 09 sectors and 79 tracks.
