Wanting to try MultiTos
- Cosmic Puppet
http://www.atarimania.com/utility-atari ... 32631.html
Found a link here but it has the extension ST. I'm totally STumpted.
Re: Wanting to try MultiTos
below you can find some links to an up-to-date multitasking systems
Which AES to use with 4MB ST ?
and when you have more ram
Minimal multitask configuration for Hatari
http://260ste.atari.org
- Cosmic Puppet
Just to confirm I don't have any emulation on the go. Just interested in physical ST. Also what does AES stand for?Cyprian wrote: Mon Oct 28, 2019 10:41 am below you can find some links to an up-to-date multitasking systems
AES is a key part of TOS - Atari operating system
Check a slide 8:
Check a slide 8:
I've extracted them for you.Cosmic Puppet wrote: Mon Oct 28, 2019 10:09 am http://www.atarimania.com/utility-atari ... 32631.html
- Cosmic Puppet
Awesome! Thank you for that. I can created test setups with UltraSatan (Amazing device with PP Driver)exxos wrote: Mon Oct 28, 2019 11:57 amI've extracted them for you.Cosmic Puppet wrote: Mon Oct 28, 2019 10:09 am http://www.atarimania.com/utility-atari ... 32631.html
1.zip
Can you direct me to that extractor? I found one for MSA files which allows me to create a floppy disk of the files but haven't found anything for ST files. Totally confused by all the formats and can't tell emulator extensions from actual atari ones. I even mistook MSA for a potential virus at first as that's a thing on windows.
- Cosmic Puppet
I'm really interested in this but it won't work.Cyprian wrote: Mon Oct 28, 2019 11:51 am AES is a key part of TOS - Atari operating system
Check a slide 8:
I used steem emulator to do it. Yeah so many file formats its mad. I only know MSA and ST formats work in steem.Cosmic Puppet wrote: Mon Oct 28, 2019 12:44 pm Can you direct me to that extractor? I found one for MSA files which allows me to create a floppy disk of the files but haven't found anything for ST files. Totally confused by all the formats and can't tell emulator extensions from actual atari ones. I even mistook MSA for a potential virus at first as that's a thing on windows.
- Cosmic Puppet
I found it online, thanks for making me aware of it's existence.Cosmic Puppet wrote: Mon Oct 28, 2019 12:46 pmI'm really interested in this but it won't work.Cyprian wrote: Mon Oct 28, 2019 11:51 am AES is a key part of TOS - Atari operating system
Check a slide 8:
ST images, are actually generic, raw floppy sector images, same as IMG.
