Recording Audio from the Atari STFM's sound chip.
- Cosmic Puppet
I'm wondering if it's possible to have a stereo out from the Atari STFM without using the ROM port? I want to compose with the chip using maxYMiser.
Re: Recording Audio from the Atari STFM's sound chip.
yes, there is YM2149f stereo modification:
http://www.atari-forum.com/viewtopic.php?t=1627
and there is a nice player Ay_Emul, where you can play YM modules in stereo:
https://bulba.untergrund.net/emulator_e.htm
http://260ste.atari.org
YM chip has 3 channels in fact. So you have chose a channel and split the track and run it to its own audio amp.
exxos wrote: Sun Oct 27, 2019 10:23 am YM chip has 3 channels in fact. So you have chose a channel and split the track and run it to its own audio amp.
If you're going to use it in a modern composition, you might as well record each of the three channels onto its own audio track. Then you are free to mix it as you like.
Good pointkeli wrote: Sun Oct 27, 2019 11:05 am If you're going to use it in a modern composition, you might as well record each of the three channels onto its own audio track. Then you are free to mix it as you like.
- Atari74user
It is possible, I bought one of these new, arguably where stereo mods really get their inspiration from: http://www.computinghistory.org.uk/det/ ... ety-Board/Cosmic Puppet wrote: Sun Oct 27, 2019 1:13 am I'm wondering if it's possible to have a stereo out from the Atari STFM without using the ROM port? I want to compose with the chip using maxYMiser.
Currently I simply use my monitor cable which has a 3.5mm out. There are various options with this route, Google search: https://www.google.com/search?rlz=1C5CH ... CAs&uact=5
AtariTOSser
Medusa Hades 060 512mb, ET4000 / MACH64 | Atari Falcon 14mb, 68882, 8gb CF, Steinberg FDI, FA8, GigaFile & CT60e | Atari Jaguar, GD, Skunkboard & Cat Box | Atari 520STFM 4mb, Exxos Booster, TOS switcher, OverScan, UltraSatan, PARCP-USB, Unicorn-USB, ICD Link 2, ADAP, ADAP II, Lynex, ADAS-ST, SoundPool MO4, Steinberg MIDEX, SMPII, Emagic Log 3, C-Lab Unitor 2, Combiner & ExPort...
- Cosmic Puppet
I think this will be my favourite option as I prefer plugins like the Ultrasatan that don't require any modification. Would it be possible to have this with a stereo output?Atari74user wrote: Sun Oct 27, 2019 4:00 pmIt is possible, I bought one of these new, arguably where stereo mods really get their inspiration from: http://www.computinghistory.org.uk/det/ ... ety-Board/Cosmic Puppet wrote: Sun Oct 27, 2019 1:13 am I'm wondering if it's possible to have a stereo out from the Atari STFM without using the ROM port? I want to compose with the chip using maxYMiser.
- Cosmic Puppet
Cosmic Puppet wrote: Sun Oct 27, 2019 5:53 pmI think this will be my favourite option as I prefer plugins like the Ultrasatan that don't require any modification. Would it be possible to have this with a stereo output? Also, what do you plug in to? I would no doubt need some sort of extension. Having said that I'm going to ring up Cool Lovelties tomorrow and ask them if they can make one.Atari74user wrote: Sun Oct 27, 2019 4:00 pm
- Cosmic Puppet
That would definitely be the best sounding.keli wrote: Sun Oct 27, 2019 11:05 am
- Atari74user
The former would be stereo, the latter mono, but I connect to a Mackie 1604VLZ4 mixer amongst other computers and instruments, and split the sound signal if I need to from the VGA cable using a 3.5mm to 'stereo' unbalanced cable, or not using an unbalanced XLR to save on inputs and channels on my mixer. Stereo from the YM is not a biggie for me, as I can split the mono signal via my mixer and add outboard effects. That said I mainly use my Falcon for that sort of stuff, but still it works pretty well. I actually haven't opened my Tweety Board, I am still intrigued by how well it would sound myself, by all accounts, it's supposed to be a simple but effective mod.Cosmic Puppet wrote: Sun Oct 27, 2019 5:53 pmI think this will be my favourite option as I prefer plugins like the Ultrasatan that don't require any modification. Would it be possible to have this with a stereo output?Atari74user wrote: Sun Oct 27, 2019 4:00 pm
AtariTOSser
