Aros on TerribleFire
- Admin sponsor
Does anyone have any experience with Aros 68K. I've never managed to get it to work even on the later Tf330/tf536/tf360 series boards.
Seems to me the TF360 is made for AROS.
- Admin sponsor
Re: Aros on TerribleFire
Does anyone know how to write a HDF image to CF card ?
Winimage will write HDF bud, obviously the image must be the same size or smaller than your CF
Don't forget to run Winimage as Administrator, otherwise you'll be scratching your head
- Admin sponsor
i havent found a way to make it write HDF.. only seems to like VHDsupaduper wrote: Sat Sep 14, 2019 7:28 pm Winimage will write HDF bud, obviously the image must be the same size or smaller than your CF
Is it failing to write or just not picking the file up?terriblefire wrote: Sat Sep 14, 2019 9:01 pmi havent found a way to make it write HDF.. only seems to like VHDsupaduper wrote: Sat Sep 14, 2019 7:28 pm Winimage will write HDF bud, obviously the image must be the same size or smaller than your CF
Version 9.0 :
Run as Admin.
"Disk" menu.
Restore virtual Hard Disk image on physical drive.
Choose device from list.
Change file extensions to *.*
Choose and open .hdf
Yes to begin writing straight away.
*Edit* No 'happy' message when writing completes, just returns to main window.
win32diskimager works
- Admin sponsor
I'll give them a go and report back
I will just add If you are creating the VHD on WinUAE , I found that when I tried setting up a system VHD and then writing it to Cf it never really worked for me, that`s why I always set up my systems on a real CF first using WinUAE and then imaging it , never have probelms this way
- Admin sponsor
The system already exists i'm trying to dump it onto a CF card..supaduper wrote: Sun Sep 15, 2019 10:01 am I will just add If you are creating the VHD on WinUAE , I found that when I tried setting up a system VHD and then writing it to Cf it never really worked for me, that`s why I always set up my systems on a real CF first using WinUAE and then imaging it , never have probelms this way
http://eab.abime.net/showthread.php?t=98062
Basically I'm trying to see how AROS gets on a CD32 with an 80Mhz 060.
