TF536 on A500
68030 + SDRAM + IDE
8 Bit Dreams
TF536 on A500
Post by 8 Bit Dreams »
Hi guys,
decided to do my beta tests more organized, so everyone can find information easily by schoosing model he interested in, instread of searching all posts through till he's able to find information needed.. So her we go:
TF536 on A500
CPU: 030
FPU: No
RAM: 64MB
IDE: Yes, GAYLE emulated
SPI: No
FlashROM: No
Fit without Relocator: No
Relocator: Available (DjBASE) www.amigaworld.de, may be used as is, NOT Indivision friendly!
TF536 fits into A500 with help of a relocator. Installing the card without it will lead to the situation that keyboard lays on the cpu, and upper case can’t be closed.
Need to point out that dimensions of the accelerator card are slightly different, hence old 90° TF53x relocator can’t be used (one of the big caps is in way and need to be bent with the risk to be damaged). I used a relocator designed by DjBASE from www.amigaworld.de, this fits nice, allows to close lid properly, also allows to use KS switcher and Megachip upgrade (NOT socketed one - Megachip need to be soldered directly on the motherboard!)
As about TF536 itself - it works on A500 just as it should, nice and stable without any crashes or unexpected gurus. Haven’t stumbled on any bugs till now.
Was also tested with RTG card and found out that it works just like it should. Like it!
IDE provides 1.3MB/s out of the box. Installing muFastROM gives good boost, bun You need a full CPU with MMU support to be able to use it.
kludge
Re: TF536 on A500
Post by kludge »
Nice flashrom ;) Did you get it to work or is it still misbehaving? I haven’t had time to look into the issues I’m having, so you quite possibly have the only working one ATM :D
My lack of focus:
go0se
Re: TF536 on A500
Post by go0se »
Thanks for sharing this info. Can you post some photos of the capacitor placement issue you mention when using the 536 with a 90 degree (Kipper2k) relocator?
Just placing the card and relocator lightly over where they should sit in the CPU socket for a photo will be sufficient to demonstrate, no need to force anything :)
Would there be enough clearance if the cap is installed horizontally, i.e. lying flat across the motherboard? and if so would there be any issues closing the case?
Danke.
PaulJ_2.0
Re: TF536 on A500
Post by PaulJ_2.0 »
kludge wrote: Sat Jul 06, 2019 8:40 am Nice flashrom ;)
Can I get one from you? I dont mind making it work with mods :D
8 Bit Dreams
Re: TF536 on A500
kludge wrote: Sat Jul 06, 2019 8:40 am Nice flashrom ;) Did you get it to work or is it still misbehaving? I haven’t had time to look into the issues I’m having, so you quite possibly have the only working one ATM :D
Upper part of the rom seems to be working fine, choosing second half is not working correctly in my opinion. ive programmed DiagROM v1.1, and it jumps to CIA test right at the start, just like button "6" were pressed...even with keyboard disconnected
go0se wrote: Sat Jul 06, 2019 9:16 am Thanks for sharing this info. Can you post some photos of the capacitor placement issue you mention when using the 536 with a 90 degree (Kipper2k) relocator?
It wasn't Kipper, it was Mr.Flibble initially, then SukkoPera redrawn it to clear ROM ic, so kickstart may be removed now..
go0se wrote: Sat Jul 06, 2019 9:16 am Would there be enough clearance if the cap is installed horizontally, i.e. lying flat across the motherboard? and if so would there be any issues closing the case?
Yup, just heated up cap legs with soldering iron and bent cap away, now its fit, so persons who have indivision still may use this relocator, however i prefer 2MB of Chipram over Indivision... ;)
go0se
Re: TF536 on A500
Post by go0se »
Excellent, thanks for the photos, looks good! Apologies, I thought the relocator was another Kipper2k design but I haven't Iooked at it for so long that I'd forgotten :) I also have the SukkoPera version of the PCB with the extra ROM clearance so good to see that it fits with a bit of rework to the cap.
kludge
Re: TF536 on A500
Post by kludge »
8 Bit Dreams wrote: Sat Jul 06, 2019 8:39 pm Upper part of the rom seems to be working fine, choosing second half is not working correctly in my opinion. ive programmed DiagROM v1.1, and it jumps to CIA test right at the start, just like button "6" were pressed...even with keyboard disconnected
I really need to sit down and have a look at this. The problem is that my TL866II+ doesn't seem to want to program the chip while it's soldered to the board, but programmed the loose chip fine. And of course I byte swapped one time too many before programming it :D
PaulJ_2.0 wrote: Sat Jul 06, 2019 9:32 am Can I get one from you? I dont mind making it work with mods :D
PM is coming.
My lack of focus:
Homer79
Re: TF536 on A500
Post by Homer79 »
Does the adapter for the TL866II 29F adapter still have copy protection? I know the TL866 adapter does
kludge
Re: TF536 on A500
Post by kludge »
Homer79 wrote: Sun Jul 07, 2019 6:53 pm Does the adapter for the TL866II 29F adapter still have copy protection? I know the TL866 adapter does
Does it? How does that work? And would it explain why I can't program the chip when it's soldered to my pcb?
(Sorry for the thread jacking)
My lack of focus:
Homer79
Re: TF536 on A500
Post by Homer79 »
I found out after buying my 3rd adapter, trying to get the 29f800 working. The top chip is a PIC
I was going to do a similar adapter, but the copy protection I couldn't get around. I settled the adapter for my GQ-4X
Return to “TF536”
