Atari XEGS tips?
project23
Atari XEGS tips?
Post by project23 »
Hey guys,
So when I was a kid I briefly had an XEGS before getting hold of an Amiga. I went up into my mums loft today and not only did I find it, but it still works! Passes the memory tests and everything.
So, i'm pretty new to atari let alone 8-bit... Looking for some pointers.
I was going to order an sio2pc from somewhere... this a good idea or are the sd card readers better?
Looking forward to playing pacman... i have absolutely no idea when it comes to other titles though, lol. I sorta skipped over the 8-bit era pretty quickly.
Was thinking of retrobriting it? The keyboard is pretty yellow, but the xegs system itself isn't too bad actually. I take it people retrobrite these XE models just like the Amiga/ST?
Cheers all,
John
Re: Atari XEGS tips?
It's weird, I've had a 65XE from new, same era, and the plastic hasn't yellowed at all. Personally I don't do retrobrite, but I can perhaps help with the other things.
I have an APE and an SIO2PC from AtariMax. It's great if you want to emulate all Atari peripherals on a PC, but it does tie you to having a PC/Laptop close by, which is a pain.
There is a very positive side though, in that you can connect a 1050 directly to your PC and actually create ATRs (Disk images) from originals. Lotharek does a similar SIO2PC adapter, which is USB and cheaper than Atarimax, but I don't think the software allows much more than emulating a disk drive/cassette deck. I may be wrong, I don't have one, but definitely worth a look too.
If you just want disk drive emulation, I'd go for an SIO 2 SD, it's much more convenient.
Also from Lotharek, is the Ultimate 1MB, which I upgraded my 800XL with, you can see here: https://www.exxosforum.co.uk/forum/viewt ... =44&t=1923
My advice, have a look here: https://lotharek.pl/ and here: https://www.atarimax.com/
Return to “8 BIT CORNER”
