The TF536 on a CDTV (Project Abandoned)
- 8 Bit Dreams
- Moderator Team
We've done some tests on CDTV today. atm TF536 is booting on it but CD craps out..
Does anyone know what CDAC signal is needed for, and why it is feeded externally on Turbo CD CDTV accelerator?
Also Spidi has an external wire on his board and Matzes A1k 8 MB board has an external CDAC signal wire also...
Answered my own question.
Well seems Stephen was right, CDAC is here for bus arbitration.
http://amigadev.elowar.com/read/ADCD_2. ... e029E.html
- Admin sponsor
Re: The TF536 arrives
I dont need this from the system as i'm already recreating these clocks. What i do think is an issue is the scsi.device I think there are two versions of this device between the two roms.CDAC Clock
This is a 7.16 MHz system clock (7.09 MHz on PAL systems) which
trails the 7M clock by 90 degrees (approximately 35ns).
- 8 Bit Dreams
- Moderator Team
Yes, there are two of them, this is 100% true, one sits in regular KS rom while other one is placed in extended ROMS.
don't know what does it mean to us?
- Admin sponsor
Ok i dont think this is true.. I checked... its cdtv device?8 Bit Dreams wrote: Sat Jun 15, 2019 7:44 pm Yes, there are two of them, this is 100% true, one sits in regular KS rom while other one is placed in extended ROMS.
stephen@debiandev:~$ romtool scan /media/sf_shared/CDTV-Extended-ROM-v2.7-1992-Commodore-CDTV.rom
@000000b6 +00003bbc NT_LIBRARY +105 exec.library exec 37.201 (28.1.92)
@00003bbc +00003bd6 NT_UNKNOWN +5 alert.hook alert.hook
@00003ca0 +0000541a NT_DEVICE +8 cdtv.device cdtv 35.12 (28.1.92)
@00005428 +00005516 NT_UNKNOWN +5 setpatch setpatch 37.3 (31.10.91)
@0000558c +000087ec NT_DEVICE +10 A590/A2091 IORequest handler SCSI/XT driver by SMB (01.05.89)
@00008822 +000091c8 NT_LIBRARY +103 utility.library utility 37.3 (13.2.91)
@0000920c +00009830 NT_DEVICE +45 battclock.resource battclock 38.1 (10.3.91)
@0000983c +0000a47e NT_LIBRARY +63 debox.library debox 1.8 (16.10.91)
@0000a48e +00035080 NT_LIBRARY +0 playerprefs.library playerprefs 2.2 (7.11.91)
@0003508c +00038468 NT_LIBRARY +2 cdfs.library cdfs 24.9 (22.10.91)
@000386d4 +0003a4ba NT_LIBRARY +7 cdg.library cdg 2.10 (3.2.92)
@0003a546 +0003adce NT_DEVICE +64 bookmark.device bookmark 6.6 (31.1.92)
@0003add8 +0003c092 NT_UNKNOWN -32 CDTV Bootstrap cdstrap 9.7 (12.11.91)
Second. I could not make fs-uae boot as a CDTV with Gayle.
- 8 Bit Dreams
- Moderator Team
Re: The TF536 on a CDTV
Hmm.. now im a bit unsure...But how can we explain this:
KS 1.3 (stock rom) doesn't have scsi.device in it, right? Yet SCSI is working!?! (Remember a small adapter ive sent You in previous parcel, this is it)
this SCSI adapter may be plugged into expansion port, it has only scsi chip, no rom, so this makes me think a device from extended rom is used, however, it seems it is called different, not scsi.device so it may be cdtv.device...
So what we need - is to fool system and let load CF card instead of SCSI.
This will need a separate firmware for CDTV, it will not work on other Amigas, but its totally fine since this lady is something "special"
So please try to recode entry to this device instread of scsi.device in main KS 3.1, this should work
- Admin sponsor
CF card is scsi (scsi.device). What you are describing cannot be done in the firware. I can map the IDE interface to a different memory location thats about it.
These CDTVs are really crap. it doesnt even reliably boot a CD with the 68k in it.
- 8 Bit Dreams
- Moderator Team
Might be caps issue, have resurrected several drives this way..
Can You please explain why this can't be done? it remains scsi all remains the same, we'll be just a little bit sneaky by calling different libary from a different location (extended rom instread of usual ks)...
- Admin sponsor
Because only one driver can be loaded at once and there is no way i can prevent one or the other from being loaded with a blob of logic that controls the bus signals.8 Bit Dreams wrote: Sun Jun 16, 2019 2:33 pm Might be caps issue, have resurrected several drives this way..
- 8 Bit Dreams
- Moderator Team
Ok.. i was just wondering why scsi hard drive is working fine in pair with CD even with ks 1.3..
Was hoping, if hard drive isn't in use - CF can be used instread
- Admin sponsor
I'm not really following this. KS1.3 doesnt have a scsi.device that uses gayle. So its highly unlikely that the unit numbers would be the same even if was scsi.device on a KS3.1. Something needs to change with CD0: Otherwise its looking for a CD on the IDE slave.8 Bit Dreams wrote: Sun Jun 16, 2019 2:44 pm Ok.. i was just wondering why scsi hard drive is working fine in pair with CD even with ks 1.3..
Now i dont know if any of this is a problem. Right now all i know is the CDTV developer guide says that all access to the CD Drive goes through cdtv.device. Reading bytes, playing disks... all through that device. maybe there is a scsi.device layer on top. There is no "scsi.device" in the CDTV extended roms (see above).
My CDTV does not spin the drive with a burnt CD in very often. I burned the Weird Science disk at 1x speed and it works sometimes with a 68000 in the machine. hangs forever waiting for the disk to spin up with the 030 in the machine.
I also strongly suspect the 030 cache bug is getting involved here because they changed DMAC between the CDTV and the A3000 so that the addresses werent longword aligned.
