exxos 534 blog - Atari
PhilC kindly sent me one of them.. see blow his blog..
https://www.exxosforum.co.uk/forum/viewt ... =68&t=1704
I had to mash it on top of my IDE interface as I needed to add 206 decoding onto it.
I had to run GB6 from cartridge as I could not get the floppy drive working ( I just kept getting 2 bombs on floppy access)
But in any case here are the current results versus a stock machine. So I think we need some firmware tweaks :)
Re: exxos 534 blog - Atari
Yep, that's about what I got GBench wise.
I used the IDE too, which has now conveniently stopped working
Tiny update of sorts.. I have been having issues downloading the ISE, but its finally downloading..
I'm a windoze guy at home though... If anyone can point to to a dummies guide to getting started to compile the 534 code to program the card, please let me know...
It is on my to do list to fiddle with TF's source to get it running as fast as possible on the ST.. Work will likely be ongoing for some time with so many projects all happening at once, but will get there eventually :)
So the current 534 was designed to get its performance from running code/rom in fast ram. TOS seems to be less good (doesn’t?) at allocating fast ram by default unless you ask for a block of chip ram specifically. Hence the performance is poor.
The reason for getting the timing exactly stock (or slower) is because many fastram cards have no DTACK wired up so the rely on the CPU latching the data in S7 and they don’t have the data ready until then
EDIT: If that’s a revc then you have all the address pins available to decode ROM..
Ping me an email tonight and I’ll send you the latest ST branch I have in a form you can run on Windows
After 20 attempts it finally downloaded and now installing :ball:
Found my programmer, but the cable was hacked to program the CT60 ages ago, will have to order a new one :roll:
Finally installed...
Can't even find anything which even suggests connecting the programmer in the menus :roll: :shrug:
Start the “impact” program. 64 bit version id you have a 64 bit machine. Just like Quartus the programmer is a separate program (its integrated but describing how to get to it is more difficult)
See https://startingelectronics.org/softwar ... oject-ISE/
ah, the problem is I I need to create a new project relevant to the 534.. which has the IC's you used, pinmaps etc, someone must have used windows version and already set all this up at some point surely ?
Return to “TF534 (OBSOLETE)”
