Hi Stphen,
may i kindly ask You to send me a TF534 firmware WITHOUT INT2 workaround?
wanna use old good method with INT2 wire, because IDE speed is much higher then..
Thank You
TF534 Firmware request
- 8 Bit Dreams
- Moderator Team
- Admin sponsor
Re: TF534 Firmware request
There is a 100ns per block difference in speed. Its virtually unnoticeable.
- Admin sponsor
i looked at the code. Just connect the INT2 wire and you have what you want. It only takes the INTREQR patch path when the values differ.
- 8 Bit Dreams
- Moderator Team
Oh thanks! Will try and report
I was curious and hooked up INT2 just to see what would happen. Note this is on the February 2019 firmware (r2c).
With INT2 hooked up, the IDE speed didn't make a difference on my machine - SysInfo showed 1.1 MB/s with and without.
With INT2 I did get incredible results on AIBB - 700 times A600 speed. Unfortunately that's probably a bug
. Also Frontier froze on the intro.
