bare minimum components
- roy-forest-fc.goodall
what are the bare minimum components required to program cpld's on tf534?
- Admin sponsor
Re: bare minimum components
Both CPLDS and the regulator.
so no caps etc then?
- Admin sponsor
The regulator caps yet.
To ID the jtag chain and program you can probably get away with no caps on a 4 layer board.
Ok thanks for the info
one final question
Do i need the flash mem/rom installed to use the tf534 in a 500
- Admin sponsor
Not at all
so I lied about one final question
what is the best firmware to use?
- Admin sponsor
Use the latest from the TerribleFire binaries github page
and which end is pin one on the ide connector
and you are a top man for answering these questions
