Case for 520ST PSU remake
Gcode files for 3d printing the remade PSU case. These are set to print faster, so quality may not be as high as you'd wish, if not change the layer thickness from .3 to something less in your prefferred software.
PSU_Case.zip
(6.26 MiB) Downloaded 325 times
!Message from: Moderator
@rubber_jonnie, we have placed your attachments in-line so they display correctly in your post. Here's the how-to guide.
ctirad
Re: Case for 520ST PSU remake
Post by ctirad »
Thanks, but why do you distribute gcode instead of an stl?
I'd like to slice it for my printer and filament setup.
ctirad wrote: Thu Sep 26, 2019 12:33 pm Thanks, but why do you distribute gcode instead of an stl?
Sorry, that was an oops on my part, I uploaded the wrong ZIP file. New one is attached.
Can also be found on Thingiverse: https://www.thingiverse.com/thing:2701695
PSU_Case.zip
(383.91 KiB) Downloaded 264 times
Also, don't do what I did, and try to get the print time down by changing the layer height etc, it made my print finish faster, but I had a lot of problems with the top vents.
Return to “3D MODELS”
