OT: Analogic CD32 died :(
68030 + SDRAM + IDE
alenppc
Post by alenppc »
So the CD32 I got from Analogic a couple of weeks ago has died out of the blue. I hadn't had the chance to recap it yet, but now I get no power at all on the board... dammit.
Re: OT: Analogic CD32 died :(
alenppc wrote: Fri Apr 12, 2019 2:08 pm So the CD32 I got from Analogic a couple of weeks ago has died out of the blue. I hadn't had the chance to recap it yet, but now I get no power at all on the board... dammit.
How odd. I have one that needs the audio amps looked at. And Viktor has an absolutely mint one.
That sounds like a dead short somewhere or a dead PSU.
Gooeyblob
Post by Gooeyblob »
My friend bought one a few weeks ago from there and the PSU was DOA!
alenppc
Post by alenppc »
Something burned out for sure, I powered it up and the power went away, but the PSU didn't go into short protection, just kept running and it works fine on the other CD32. I can't see any scorched traces or any visual cues as to which component failed. I guess I will ask John Hertell for some pointers. Any fuses on this motherboard??
alenppc
Post by alenppc »
Ok, R801 burned out. I am going to replace it with a 1 ohm resistor and see if that burns out again. I guess it acts like a fuse.
R801 looks like a pad for a ferrite bead/fuse or 0R resistor if they cheaped out.
alenppc
Post by alenppc »
It was a 0R, but since I don't have a 0R, I replaced it with a 1 ohm. Now the board powers up again. I also recapped it completely while I was at it, lots of leakage under the 22uF caps.
Anyway, I get sync on the screen but black screen. Even diagrom doesn't boot. No change with a 330 plugged in or without it... Dammit...
8 Bit Dreams
Post by 8 Bit Dreams »
alenppc
Post by alenppc »
It doesn't look the same, mine was working fine until it suddenly lost power when R801 burned out for some reason. To be fair, I was using it without recapping it due to lack of time, and the 22uF and some 100uF caps had leaked.
The power was restored after replacing R801 but now all I get is black screen. I also recapped the whole thing.
I am suspecting the PSU might have sent a high voltage on the +5V, causing the burn out, but then who knows what else might have gotten damaged. Although it is strange as I am using a brand new AT PSU (yes, they are still made).
alenppc
Post by alenppc »
OK, it lives once more.
I noticed that 1ohm R801 was getting really toasty so I replaced it with a 0R taken from a dead A600 motherboard and it booted immediately. Also my AT PSU is going in the garbage. I strongly suspect it was responsible for killing the R801 in the first place.
Return to “TF330”
