Hello I'm hoping someone can guide me, I have just opened the Atari TT and noticed the rear fan behind the hard drive is not connected, this is probably best its wiring looks a bit dodgy and there are no markings to indicate voltage. I would like to replace this fan, the nearest connection is a 3 pin J102, but without knowing I don't want to risk it.
Thanks
TT030 replacement case fan and where to connect
XEGS, STF/FM/E CBM 64 VC20 PET , ZX81, ZX +3 Harlequin ZXuno
Re: TT030 replacement case fan and where to connect
Hi zack4mac - I have replaced my fans in TT with these https://noctua.at/en/nf-a6x25-flxzack4mac wrote: Sat Apr 06, 2019 9:56 am Hello I'm hoping someone can guide me, I have just opened the Atari TT and noticed the rear fan behind the hard drive is not connected, this is probably best its wiring looks a bit dodgy and there are no markings to indicate voltage. I would like to replace this fan, the nearest connection is a 3 pin J102, but without knowing I don't want to risk it.
Thanks
They are very quiet. Also you could use a fan break out board like this to power the fans
https://www.exxosforum.co.uk/forum/view ... =796#p5649
Later revisions of TT didn't even have that fan installed. For reference:
J102 as you said. Pin 1 is +12V. Pin 2 & 3 are ground.
As DoG mentions pin 2 & 3 are ground so if you get the Noctua its a 3 pin connector.
DONT just plug it straight in. You will be able to plug just the (EDIT: +12V) and GND pins of the socket into the connector to power the fan.
Here is a picture of the pinout of the Noctua 3 pin so you only plug the red and black part of the socket in and not the yellow.
https://noctua.at/media/wysiwyg/faqs/no ... v_fans.png
Why 5V? Isn't the fan linked in the previous post a 12V one?Icky wrote: Sat Apr 06, 2019 11:01 pmDONT just plug it straight in. You will be able to plug just the +5V and GND pins of the socket into the connector to power the fan.
Good spot mikro - was on auto pilot typing in the answer. Will correct.mikro wrote: Sun Apr 07, 2019 10:42 amWhy 5V? Isn't the fan linked in the previous post a 12V one?Icky wrote: Sat Apr 06, 2019 11:01 pmDONT just plug it straight in. You will be able to plug just the +5V and GND pins of the socket into the connector to power the fan.
EDIT: Corrected. Thanks.
I took the advice of Icky and ordered two nf-a6x25-flx from Amazon at £25.60 arrived a few minutes ago and will be connected without the speed control.
Quite excited, cant wait to start using it!
Cheers everyone
Cheers everyone
