Recommendations for cheap Ultrasonic cleaner
Hi All,
As title if you'd be so kind. It won't see a lot of use, hence the cheap price requirement.
Probably biggest thing I'd do is something like a TF534 or Pak3.
Thanks.
Re: Recommendations for cheap Ultrasonic cleaner
I've got one of these...
www.amazon.co.uk/Ultrasonic-Stainless-S ... 073Z9MVN7/
But I doubt a PAK would fit in a 3L one.
My only issue with these things is they take bloody ages to heat up.. I might look at it at some point, I assume it just got a resistor bolted on the bottom of the thing.. needs a bigger one...
Thanks, will have to have a measure up and see.
What do you use cleaner fluid wise?
PhilC wrote: Tue Apr 02, 2019 7:02 pm What do you use cleaner fluid wise?
https://uk.farnell.com/shesto/utflu01/c ... dp/2759031
Ok, thanks. Might have to wait a bit before I've got room for it.
Return to “ELECTRONICS”
