TF534 Open Board View
There is an open board view file available for the TF534 builders to help diagnose.
https://github.com/terriblefire/tf534
Screenshot 2019-03-28 at 14.49.58.png (113.85 KiB) Viewed 7375 times
go0se
Re: TF534 Open Board View
Post by go0se »
Fantastic! I was just thinking the other day how an amigapcb.org type solution for the 534 would make my life a lot easier and along comes pretty much exactly what I wanted!
Cheers for putting this together TF, Is there much work involved in (I assume?) deriving this layout from the Eagle files?
The first time i did it it was work. Then i created a bat file i can drag things on and its done automatically.
go0se
Post by go0se »
Excellent, this really will be a massive help. Can said batch file be used to produce versions for the 530 and 330 or am I just being greedy now? :)
go0se
Post by go0se »
This really is gold! Decided to attack my non booting 534, logically starting with the connections to/from X1 and within 5 mins I've located an invisible short between pins 2 and 3 of trigger buffer IC4 that didn't show up with the scope. A quick re-flow later and it's booting to Diagrom serial only with a nice pink screen on the video output - :) Onward!
Again TF, a really big thank you for releasing this! Brilliant.
go0se wrote: Thu Mar 28, 2019 7:17 pm Excellent, this really will be a massive help. Can said batch file be used to produce versions for the 530 and 330 or am I just being greedy now? :)
Not really much point since you can "show <netname>" with TF530.
I have already pushed the TF330 OBV to github.
apacz
Post by apacz »
Please forgive me lame question:
opening in eagle9.3 :
Loading /home/michal/tf534-master/tf534_obv.brd ...
Error:
line 1, column 1: Expecting tag opening
Opening in OpenBoardView i can see only capacitors. What do you use for viewing?
apacz
Its an open board view file. not eagle.
FLip the board by pressing space.
apacz
Post by apacz »
10x works like a charm
Return to “TF534 (OBSOLETE)”
